Author Topic: Revo KO4 turbo kit  (Read 1989 times)
Offline Thatredgolf
Revo KO4 turbo kit
« on: August 11, 2020, 09:07:06 pm »
So I have blown my KO3 into smithereens so naturally it’s time for a KO4.
After doing some research into sourcing one of these bad boys I’ve stumbled over a the Revo KO4, is anybody running this at the moment? Would it be worth the difference in price in comparison to the OE counterpart?
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
Re: Revo KO4 turbo kit
« Reply #1 on: August 12, 2020, 01:20:48 am »
I do not know anyone with the revo K04 kit. It is just a Borg Warner K04 and they may have done some clean-up on it and got rid of the turbo muffler...so it has a direct outlet. Scroll down (link below) to see pics and they use the word "competitor" without stating which that would be. Is it a clone or genuine BW before revo cleaned it up...who knows. I would say compare the BW K04 and a turbo muffler delete. Additionally, if you see the mess those pics show inside the BW K04 turbo inlet...clean it up before installing it and voila...you have a revo K04. Power output would be no different as revo didn't modify the compressor or any internals. https://www.urotuning.com/products/revo-k04-turbo-kit-exc-software-transverse-2-0t-fsi-rt991m100300
Offline Thatredgolf
« Reply #2 on: August 12, 2020, 01:25:50 am »
Since I was planning on taking it to R-Tech to get mapped in I wasn’t too fussed about the “stage 3” package that was offered with it.
I may just find myself pieces for the conversion and get a second hand one reconditioned I guess.
Thanks mate
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #3 on: August 13, 2020, 05:11:42 pm »
Sure, if you just find a turbo and are going to tune for it, just source some MK6 Golf R injectors, HPFP internal upgrade, DV relocate if the K04 doesn't have a turbo mounted DV, and possibly a turbo muffler delete. You can upgrade the fmic and boost plumbing at some other time.
« Reply #4 on: August 14, 2020, 04:44:22 pm »
Get a brand new turbo and K04 injectors, then source everything else from ebay.  It's about £1500 worth but it's better to put the extra into the main components rather than sticking secondhand stuff in of an unknown history/condition.
Offline Thatredgolf
« Reply #5 on: August 14, 2020, 04:45:06 pm »
How about getting it reconditioned pudding?
« Reply #6 on: August 14, 2020, 05:11:01 pm »
You mean buy a scrap K04 and get it refurbed?  Yeah that's an option.  Personally I would only go to TurboTechnics for this service, but tell them you just want a standard rebuild with 360 degree bearings.  If you go for a hybrid that will add extra work to the mapping, and therefore cost.
If I were you, I would just get a base spec turbo and all the other bits, bung it on and just go for a mild remap and see what you feel about it.  You won't get much more than 330-340hp unless running everything on the ragged edge......and that won't be possible on an AXX block anyway as it has a higher compression and weaker pistons than a K04 engine.
Switching from the K03 to a K04 is already a big step up, so take it easy initially.  I'm not trying to be your Dad, just trying to stop you from blowing the engine up  :grin:
Offline Thatredgolf
« Reply #7 on: August 14, 2020, 05:19:35 pm »
So the KO4 I’ve sourced is off an S3 about 40k miles I will 9/10 get this checked out and refurbed before installation, as I’ve already swapped the block for a BWJ from the cupra but are using my ancillaries I should be good for 340 providing I switch out the injectors and intercooler right? I always had plans to KO4 the car but it’s being dictated on the cars terms and not mine I’ve had a little root around of turbozentrums website and I’ve seen they do an injector clean too so I might get them both checked over.
« Reply #8 on: August 14, 2020, 06:10:29 pm »
OK, things are sounding better now.  A 40K old snail might not even need a refurb  :happy2:  I don't know the spec of the BWJ.  Is it a CDL/BYD equivalent?  If so, it will have the lower compression and better pistons/rings etc so you can run more boost  :happy2:
Offline Thatredgolf
« Reply #9 on: August 14, 2020, 06:15:20 pm »
So the BWJ came out of a Seat Leon Cupra K1 which ran a KO4 out of the factory so in theory it should hold up the same as a BYD/CDL on R-Techs website it did fall under the same category as those.
I will be able to get a better indication when I get around to inspecting the snail in person then I’ll make the call to have it refurbed not, I think the injector clean will be a must.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #10 on: August 15, 2020, 07:08:44 pm »
Regarding the cleaning of the used injectors...inquire the cost and what they do. Here, U.S., the cost for servicing a set of four is about the cost of one new injector. The service includes the ultra-sonic cleaning and pressure testing. You will want them tested with more than 10 bar of pressure over its fuel pressure release/regulator valve(FPRV) limit on the rail. Or ask them what they do regarding testing pressure...they should know what the limit is for the FPRV you have. My FPRV has a 145 bar limit. So, you need to confirm the pressure they test them at, also, if they compare spray pattern so to know the nozzles are spraying equally. I have a set of four I just removed that have 97k miles on them. They were fouled somehow and my long-term mileage average has now gone up from 23 mpg to over 28 mpg. I am still not sure if it is worth the cost to have the removed injectors checked...and I may just toss them out. Still undecided.
