Author Topic: Viewing mk5 gti advice  (Read 2632 times)
Offline GVK
  • -Receive: 67
    • GVKmotorsport
Re: Viewing mk5 gti advice
« Reply #15 on: August 14, 2020, 11:20:02 pm »
It has a cam belt, a chain for the cam at the other end, also an oil pump chain.
Offline Tomi9870
« Reply #16 on: August 15, 2020, 11:59:47 am »
Should all three be replaced at the same time at 60k?
Offline Jb55
« Reply #17 on: August 15, 2020, 12:55:13 pm »
@Tomi9870 cambelt and water pump should be done every 4 years or 60k miles what ever comes first,
cam chain doesn’t really need to be changed until in becomes a little noisy or some like to get it changed around the 100k miles mark, that’s when I’ll be doing my chain anyway.
I believe the Oil pump chain is not normally changed there definitely isn’t any interval time for it anyway, maybe just if it become noisy like the cam chain.
Gen 3 racks are on the mk6 golf but considered a good upgrade for the mk5 golf when the rack eventually goes, normally the streering rack will start making a knocking sound or the steering wheel light will be on on the dash.
« Reply #18 on: August 19, 2020, 02:43:21 pm »
Yeah there’s no service interval on the chains but the cam one does wear out. Oil pump one seems to last forever if the car is looked after.
Gen 3 rack needs an additional £100 loom and (optionally) a software update on the J500 ABS module, which only VAG ODIS software can do......so extra cost and faff to factor in. Worth doing though as it’s a far better rack than gen1/2.
Offline RedSwede
« Reply #19 on: August 19, 2020, 03:03:08 pm »
If it has had rigorous servicing (10k or less, without fail), then you almost certainly don't need to worry about the cam follower. Mine was as new at 60k under those conditions. 2 years would only be necessary if you were remapped.
I would very much second the corrosion - and in particular the boot floor. I spent a few weekends under mine at it's 10th birthday, scraping surface rust, and doing the whole rust-remover, rust-killer, epoxy-paint, stone guard, underseal routine. Most of the car was OK, but that boot floor was covered in surface rust. Took 3 goes with the rust remover gel and wire brush to get close enough to clean to use the rust converter. Mk5s are going to get very rare in the next 5 years.
Offline andyiseddy02
  • My Ride: 2006 Passat SEL estate. 2.0 FSI T.
« Reply #20 on: August 25, 2020, 06:40:40 pm »
Hi there,
  Interestingly, I never see rusty Passats or A3s of the same vintage.  Same car essentially
 :signLOL: Never see a rusty Passat. Oh that is a good one.
« Reply #21 on: August 28, 2020, 02:42:46 pm »
Well I haven't seen any, personally  :wink:
