Author Topic: Performance issues...resolved!  (Read 10379 times)
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
Re: Engine cover woes....
« Reply #15 on: March 14, 2010, 07:05:50 pm »
I assume you have an edition 30 ?
Given what youve described, I would be checking to see if you have uploaded the new map.
Sounds like you may have reloaded stock ..
Red ED35 5dr DSG
BLOG | BUILD
Offline Boothy
« Reply #16 on: March 14, 2010, 07:29:51 pm »
Its just the normal GTi mate, not the ED30. I checked the bluefin device at the time and it defo said it had installed it.
Offline Boothy
« Reply #17 on: March 15, 2010, 12:19:49 pm »
Tried to get on a rolling road today but when I rang the local place they said they no longer had it so its not been possible. I have driven the car a bit more today on normal roads and was initially still unimpressed but then all off a sudden it seemed to have more UMPH and was pulling well right through the revs. It did that for a while and then stopped again, only really pulling up to around 4500rpm. It did the same again later on and I remember the same thing at one point when I first fitted the Bluefin. Its flat as a fart after about 4500rpm but when it changed you could definitely feel a huge difference.
Having zero technical knowledge does this sound like a likely side effect of a knackered DV? I've ordered a replacement anyway just in case and I've also spoke to Superchips who were very helpfull. They are going to have a look at the map and get back to me.
« Last Edit: March 15, 2010, 12:30:35 pm by Boothmeister »
« Reply #18 on: March 15, 2010, 01:26:28 pm »
Sounds like a strong case of finding someone near to you to log your car with vcds to narrow down possibilities.
Offline NEWEY
    • Flickr
« Reply #19 on: March 15, 2010, 01:45:48 pm »
i would look into this a bit deeper as i never had a problem with a type r even when it was in standard form my mate couldnt get away
TSR big turbo mk5 golf gti
Offline Boothy
« Reply #20 on: March 15, 2010, 05:10:12 pm »
Can anyone help me with this VCDS thing? I'm getting really worried now.......... :sad1:
« Last Edit: March 15, 2010, 05:14:03 pm by Boothmeister »
Offline Boothy
Re: Performance issues...
« Reply #22 on: March 22, 2010, 11:54:37 am »
Firstly thanks to MortyGTTDI who is meeting me tomorrow to have a look at my car with VCDS thing. Very much appreciated.
Secondly, I have bough a revision D recirculation valve as a precaution but I'm not sure how to fit it. I know I've seen something on here somewhere but I can't for the life in me find it? Has anyone fitted one that can talk me through it or can find the original post about it?
Cheers.
Offline scotta
  • Edition 30
« Reply #23 on: March 22, 2010, 12:25:37 pm »
Cheers.
Its apparently on the turbo on the K03 standard GTi's
What you describing sounds like it could be your MAF thats dodgy.
Offline liver
« Reply #24 on: March 22, 2010, 12:31:46 pm »
here is a diagram showing where its located mate
you will have to jack car up, put on stands then get under to do it. I tried to get mine off when i had a spare 15mins but due to location i found it hard
its held on by 3 bolts, not sure if its a torx or what size mate
so 3 bolts and undo the plug for the wire and its off
hope this helps
Offline Boothy
« Reply #25 on: March 22, 2010, 01:12:24 pm »
[/quote]
[/quote]
I presume when Darren hooks the car up to the VCDS it will highlight any MAF faults etc so will wait and see what he says when I meet him tomorrow. Regardless of the outcome I'm going to fit the updated DV simply as a precaution and that they allegedly a much better unit. Thats for the assistance, especially the in depth walk through that Luke (Snapey) sent me. Wish me luck! :laugh:
Offline liver
« Reply #26 on: March 22, 2010, 01:13:33 pm »
[/quote]
[/quote]
could you forward this on for me aswell please mate
Offline markymark
« Reply #27 on: March 22, 2010, 01:38:45 pm »
Ive just sorted a boost leak on my car, it doesnt show up any faults via VCDS only when data logging will it show there is a problem. SteveP did some data logs for me when we were up at UD's and from the results it suggested it was the DV at fault. My DV was ripped and when on boost it whistled alot louder than normal. All fixed now and running very strong again. :happy2:
« Reply #28 on: March 22, 2010, 01:40:52 pm »
How bad was the rip?
Offline markymark
« Reply #29 on: March 22, 2010, 01:42:43 pm »
From memory the rip was similar to that of Wigits!
