Author Topic: Rear ABS loom?  (Read 3367 times)
Offline GVK
  • -Receive: 67
    • GVKmotorsport
Rear ABS loom?
« on: August 15, 2020, 01:25:17 pm »
Whilst fitting a rear ABS sensor I've managed (heavy handed) to snap the locking tab off the connector that goes onto the sensor  :slap:
Anyone know if there is a repair loom for these, cost of and how far does it go into the car?
Offline terrier
  • -Receive: 38
  • My Ride: GTI now gone
Re: Rear ABS loom?
« Reply #1 on: August 15, 2020, 04:00:50 pm »
The broken piece will have a part number on it. Simple splice should do it. Like me you may need a magnifier to ID
Offline Octoparrot
  • -Receive: 102
Re: Rear ABS loom?
« Reply #2 on: August 15, 2020, 08:02:06 pm »
You can buy new connectors from vw or on ebay and replace it by de pinning the connector, there are some videos on YouTube.
Offline GVK
  • -Receive: 67
    • GVKmotorsport
Re: Rear ABS loom?
« Reply #3 on: August 16, 2020, 12:11:56 am »
Found this on ECS tuning.
https://www.ecstuning.com/b-genuine-volkswagen-audi-parts/rear-abs-sensor-wiring-harness-right/1k0927904aj/
right rear 1K0927904AJ will see if it's available from VW in UK.
« Last Edit: August 16, 2020, 12:14:20 am by GVK »
Offline LC5F
  • -Receive: 80
Re: Rear ABS loom?
« Reply #4 on: August 16, 2020, 12:41:12 pm »
Replacing that section of loom is likely to be a right faff.
I would go for replacement connector as suggested by Terrier & Octoparrot
The rubber boot will peel back and you just need to remove the pins and reassemble onto the replacement connector.
Personally I would be happy with a scrap yard sourced used connector, in fact grab a couple
Offline Octoparrot
  • -Receive: 102
Re: Rear ABS loom?
« Reply #5 on: August 16, 2020, 05:28:23 pm »
Offline terrier
  • -Receive: 38
Re: Rear ABS loom?
« Reply #6 on: August 16, 2020, 08:11:14 pm »
"h2fconnectors2016" on the bay of plenty :happy2:
Offline GVK
  • -Receive: 67
    • GVKmotorsport
Re: Rear ABS loom?
« Reply #7 on: August 16, 2020, 10:48:11 pm »
Thanks guys.  :happy2:
pn 6E0973702
Also pn 8T0973702 not sure what difference is?
« Last Edit: August 17, 2020, 08:17:30 pm by GVK »
