Author Topic: Diverter Valve - Would you replace a version D with a G?  (Read 1851 times)
Offline Rossimac
  • -Given: 78
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,90767.0.html
« on: August 25, 2020, 12:07:43 pm »
Hi all,
This is for my second GTI, I finally got around to inspecting the DV fitted to it (2005, 150k miles) and to my surprise it has been fitted with a version D.
I've already read version G is the best. Would you replace it with a G? I am kinda thinking yes, as I've read before that D can leak boost. It's a KO3 with only a Stage 1 map on it, so would it be likely that a D vs G wouldn't make much difference at my power level?
Thanks,
Ross.
Offline gege12372
Re: Diverter Valve - Would you replace a version D with a G?
« Reply #1 on: August 25, 2020, 12:35:23 pm »
R techs website states revision D diverters leak boost under “extreme loads”. I wouldn’t replace if the DV performs as it should at the moment.
Offline Rossimac
  • -Given: 78
« Reply #2 on: August 25, 2020, 12:52:21 pm »
thinking the same now, no need to spend money on something if it's not broken  :happy2:
« Reply #3 on: August 28, 2020, 03:46:37 pm »
I've never had any problems with Revision D, even at Stage 2+.  It's a myth they leak, and absolute nonsense they are 'designed to leak' which I've also heard/read.
G is a rubber diaphragm like A and C, so it will also tear eventually.
The fit and forget solution is either a D, or a Go Fast Bits DV+.
Offline Rossimac
  • -Given: 78
« Reply #4 on: August 28, 2020, 06:51:35 pm »
So I wonder why they went back to diaphragm design with the G? I guess we'll likely never know!
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #5 on: August 28, 2020, 11:36:29 pm »
This is the best description I have found yet;
http://stratifiedauto.com/blog/volkswagen-audi-diverter-valves-how-they-work-the-limitations-and-what-you-need-for-your-tfsi/
The Rev. D can leak...but it doesn't mean they all, or even most, will leak. It has a stronger spring. And if you have one that works...it is better than the Rev. G. With that said, I believe VW will no longer have a Rev. D and are only found and made by aftermarket oem suppliers...Vemo and perhaps Pierburg. But a Rev. G will work when you are in need of another.
« Reply #6 on: August 29, 2020, 01:47:54 pm »
God knows, cost probably.  I guess they had to invest a lot in injection moulds for the plastic piston parts, whereas with the G, they already had the tooling in place from Rev A & C.  Just a guess.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #7 on: August 29, 2020, 04:56:21 pm »
Yes, exactly. Who knows.
I replaced my original C, early on in the 30k to 35k mile range, with a D. The D wasn't on long because I went to the K04 and the AWE DV at 58k miles. So I never got to see how long the D would last.
