Author Topic: P0304 Misfire problems  (Read 4913 times)
Offline Ash_89
« on: September 01, 2020, 11:08:47 am »
Morning guys
recently noticed a misfire on my car noticeably worse when cold starting
the only code im getting on my reader (not vag com) is the P0304 misfire cylinder 4
my injectors where cleaned/serviced last October also new BKR7EIX plugs fitted at the same time , and walnut carbon clean
bits i have tried
swap coil pack and spark from cylinder 1-4 yesterday
replaced pcv pipe (going to inlet) as was slightly leaking
fuel filter changed 1/08/20
r8 coil packs around a year old
the car runs fine whilst driving boosts as normal its only on idle i get the misfire .
engine code BWJ
75K miles
[/url[url=https://www.flickr.com/photos/158705908@N03/]
CYLINDER 4 PLUG
Offline Ash_89
Re: P0304 Misfire problems
« Reply #1 on: September 03, 2020, 09:59:01 am »
Compression test was done last night
cylinder 1  182 psi
cylinder 2  178 psi
cylinder 3  187 psi
cylinder 4  187 psi
will be doing another this weekend with a leak down test aswell due to me using a fair bit of oil
Offline mjmallia
  • -Receive: 54
« Reply #2 on: September 03, 2020, 03:21:54 pm »
When was the cam chain and tensioner changed?
Had a similar problem recently with a cold misfire and had a little chain rattle. The chain and tensioner were changed recently, but one of the three cam plate seals was broken and not producing enough oil pressure at idle.......so the chain was slack and created the misfires.
Mike
South Coast
Offline Ash_89
« Reply #3 on: September 04, 2020, 09:33:08 am »
Not had the cam chain replaced mate just the cambelt last year , was yours only missing on one cylinder ?
my car does sometimes have a rattle when starting but it goes in a second
Offline mjmallia
  • -Receive: 54
« Reply #4 on: September 04, 2020, 10:00:05 am »
It did to begin with then spread out on three cylinders.
The cam chain does need checking and they can start to fail from as early as 60K miles, but between 80K-100K they are usually due these days.
I don't get any rattle at start up on mine
Mike
South Coast
Offline Ash_89
« Reply #5 on: September 04, 2020, 11:53:24 am »
Cheers mate
I did change the fuel filter recently due to a major misfire ( fuel the came out the filter was very dark ) ,im thinking due to there being nearly 30 litres in there i may have just wrecked a brand new filter when i should of drained the bad fuel
the car ran perfect after that for a couple of days
« Reply #6 on: September 05, 2020, 12:35:19 pm »
Could be the injector.  Maybe carbon fouled if the engine is using a fair bit of oil.  The ECU does a weird double injector pulse when cold to heat the cats up or something.  Maybe injector 4 is a bit lazy.   They do usually clear up with a bigger duty cycle, hence why it's fine on the move.
It is a classic failure on these engines, well, direct petrol injection in general actually.
Offline Ash_89
« Reply #7 on: September 07, 2020, 09:29:40 am »
cheers for the input mate , yes im thinking more towards injector now as well ill be taking them out and swapping 4 to 1 to see if the missfire moves
the joys of direct injection :)
Offline Ash_89
« Reply #8 on: September 14, 2020, 09:55:04 am »
Took the inlet of at the weekend to inspect the valves and injector (cyl 4)
also gave the throttle body a good clean being a tad cruddy
the offending injector  :fighting:
The inlet valves were surprisingly covered in carbon/vapor deposits (inlet walnut blast done 9 months ago) too be honest i wasn't expecting them/ looking this bad already
inlet plates just as bad
everything was cleaned also fitted new:
*pcv gasket
*bottom pcv pipe
*inlet gasket
*injector
*cam follower checked
*vac pump o ring replaced
She now runs great no misfires :)
Next job will be to clean the filthy thing
« Last Edit: September 15, 2020, 08:53:45 am by Ash_89 »
Offline mjmallia
  • -Receive: 54
« Reply #9 on: September 14, 2020, 04:13:03 pm »
Good to hear.....it is amazing how quick it builds up.
Mike
South Coast
Offline Ash_89
« Reply #10 on: September 14, 2020, 04:38:42 pm »
Totally wasn't expecting it to be that bad already lol , il be getting a fresh set of bkr7eix spark plugs this week im pretty sure it couldn't of been doing the plug much good with the misfire
Offline mjmallia
  • -Receive: 54
« Reply #11 on: September 15, 2020, 09:40:42 am »
I did the same after my misfires and inlet/injector cleaning.....runs like a dream now.
Mike
South Coast
