My GTI is drinking oil & I have some persistent fault codes which re appear after clearing.
I would be grateful for any advice you may be able to give based on your experience of similar faults
Thanks in advance.
I have scanned & uploaded..
Wednesday,02,September,2020,15:53:31:01249
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 15.7.1.0
Data version: 20150904
www.Ross-Tech.comVIN: WVWZZZ1KZ7W059905 License Plate: V10ULD
Mileage: 148100km-92025mi Repair Order:
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ7W059905 Mileage: 148100km-92025miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Not registered 0011
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 J HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0030
Revision: --H14--- Serial number: VWZ7Z0F8097584
Coding: 0403000318070160
Shop #: WSC 00791 210 87297
VCID: 2D56C5FFB415DF56C6-8078
5 Faults Found:
004243 - Bank 1; Fuel Measuring System 2
P1093 - 008 - Malfunction - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 148093 km
Time Indication: 0
Date: 2000.00.00
Time: 15:26:31
Freeze Frame:
RPM: 1400 /min
Load: 12.9 %
Speed: 38.0 km/h
Temperature: 88.0°C
Temperature: 44.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.970 V
005699 - Please check DTC Memory of Electric Load Controller
P1643 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 148093 km
Time Indication: 0
Date: 2000.00.00
Time: 15:26:41
Freeze Frame:
RPM: 751 /min
Load: 22.3 %
Speed: 0.0 km/h
Temperature: 88.0°C
Temperature: 46.0°C
Voltage: 13.589 V
008825 - Leak in Air Intake System
P2279 - 002 -
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 148098 km
Time Indication: 0
Date: 2000.00.00
Time: 15:35:31
Freeze Frame:
RPM: 803 /min
Load: 14.9 %
Speed: 0.0 km/h
Temperature: 90.0°C
Temperature: 48.0°C
Voltage: 13.970 V
001287 - Idle Control System RPM
P0507 - 001 - Higher than Expected.
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 148102 km
Time Indication: 0
Date: 2000.00.00
Time: 15:41:08
Freeze Frame:
RPM: 1048 /min
Load: 14.9 %
Speed: 0.0 km/h
Temperature: 90.0°C
Temperature: 44.0°C
Voltage: 14.097 V
008801 - Boost Pressure Control Valve (N249)
P2261 - 008 - Mechanical Malfunction
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 148102 km
Time Indication: 0
Date: 2000.00.00
Time: 15:42:46
Freeze Frame:
RPM: 2971 /min
Load: 14.5 %
Speed: 41.0 km/h
Temperature: 92.0°C
Temperature: 31.0°C
Voltage: 13.970 V
Readiness: 0110 0101
