Author Topic: Jim's Polo GTI 1.8T  (Read 27650 times)
Offline GLIDN
Re: Jim's Polo GTI 1.8T
« Reply #45 on: February 27, 2012, 05:14:13 am »
honestly, I would not bother with a Forge DV on the 1.8T. Just get an OEM 710N (225hp Audi S3 DV) no ongoing maintance and ours has held up for almost 100000km's.
As for the fluttering sound.
I only just recently found out these motor's have the trouble of turbo bolts coming loose. I'm guessing you have a 2007 version?
I had a guy over here in NZ with the same issue. Ended up replacing the turbo bolts and gaskets. (manifold to Turbo) will confirm in the next day or two when I see him again.
I can't point to this being the solution, but could be something to look at?
Good luck with this, let us know when a resolution has been found?
Offline cal tdi
  • dub or die
« Reply #46 on: February 27, 2012, 04:08:34 pm »
You'll have to let me know what that poorboys stuff is like bud!?
Definitely going to have to invest in the next month or so when I find my new motor. RIP trusty mk5.
Tom, ben - so your both Beemer boys now??
Candy weiß Mk6 GTI - Stage 2
Offline NotNormal
« Reply #47 on: February 27, 2012, 04:59:33 pm »
Yes bud, I'm on my second 335d coupe - loving it, ticks all the boxes for me :D
Don't judge me by your ability !
__________________________________
Current daily crapper - Audi A6 Avant 3.0tdi SLine Quattro
Previous favourite rides :
BMW E92 335d M/Sport (351/520)
BMW  E92 335d SE (339/500)
Golf MK5 GT170 Diesel Sport (220/330)
Audi S4 (B6) - Noggy blue (366bhp)
Evo VI (6 ;) ) RSII - Scotia White (420bhp)
Astravan Sportive 1.9 CDTi - 190bhp
Astra GTE (MK2) Turbo (
Offline jimlad09
« Reply #48 on: February 27, 2012, 08:48:35 pm »
Hello GLIDN, I've only just started posting after a while off and im happy to say that the bailey DV was infact working fine and the noise was, as you've pointed out the bolts coming loose causing a gasket to slip slightly. This gap was allowing the escape of air and causing this fluttering noise. Sounds like you've got a similar problem, the resolution was to drop the turbo and associated components, locate the leaky seal and replace. Touch wood so far no reoccurances!
Thanks for the heads up on the audi DV tho, useful to know! Where abouts in NZ you based?
Yeah cal im having a saturday morning when im back from jet setting down the workshop to get it washed, sealed and waxed
remapped tho...would tick my box  :happy2:
Offline GLIDN
« Reply #49 on: February 27, 2012, 10:36:33 pm »
I'm in Auckland,
Yeah will be interesting to see if the two polo's had the same issue about the leaking gasket.
still enjoying the car?
Offline NotNormal
« Reply #50 on: February 27, 2012, 10:38:18 pm »
340bhp - 510lbs/ft ...... it certainly does :D
Offline jimlad09
« Reply #51 on: February 27, 2012, 10:44:24 pm »
I'm in Auckland,
Ah nice I work with a guy from Auckland. Yeah drop me a line when you find out, I know mine was running too much boost after the remap. Unfortunately as it was under warranty still the dealership simply wound in the actuator effectively killing the boost. Took alot of time and effort to get it rebalanced. And yeah love it, like a little go kart. Have started looking for a replacement but il struggle to part with her!
you know what your problem is? your all torque....sorry couldnt resist
