Author Topic: Hella Xenon look headlights mkv golf  (Read 72242 times)
Offline Matto
  • -Receive: 116
Re: Hella Xenon look headlights mkv golf
« Reply #120 on: February 05, 2012, 03:31:24 pm »
I'm looking at gettin a set from here.
http://www.ebay.co.uk/itm/200579708297?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Are these the same lights as the OP? One of my headlights actuators seems to have broken, so could be the ideal time to get some of these  :evilgrin:
I believe they are yes. A seller called Tuning Fanatics.
Offline Syrag64
« Reply #121 on: February 05, 2012, 03:34:28 pm »
Cheers Matto, going to have a quick search to see if i can find any cheaper otherwise i will probably get a set  :party:
Black 2007 GTI Manual, Stage 3 K04, R32 Bumper/Exhaust, WALK, adj rear ARB, KW1's, Twintercooler, Twintake, 18's (winters), 19's (summer) modified dectane LED rear lights, NQSBBK, Forge dump valve, Xenon look headlights with 5000k HID, 3" downpipe with sports cat, TT wishbones, uprated HPFP, Sach Uprated Clutch, Quaife LSD, VT & THS Engine Mounts.
To be fitted: Reverse Camera & uprated headunit.
Future plans: De-dent & Detail
Offline vRS_Pagey
  • -Receive: 59
« Reply #122 on: February 05, 2012, 04:31:34 pm »
If you find them cheaper be sure to post a link.  :wink:
Offline WT007
« Reply #123 on: February 05, 2012, 06:31:53 pm »
These are from tuning fanatics with 6500k
beam pattern is not as good as OEM
hugh jass
« Reply #124 on: February 05, 2012, 06:44:51 pm »
Nice pics WT. Im sure with a bit of tweaking that beam could be improved upon.
Offline WT007
« Reply #125 on: February 05, 2012, 06:52:15 pm »
I can only see two white plastic adjusters one up and down and one left and right. does any one who has these know how to make these better?
Offline Syrag64
« Reply #126 on: February 05, 2012, 07:50:20 pm »
If you take to an MOT place i'm sure they would set them up the best way, I've just ordered a set of these hoping that they set up ok  :surprised:
Offline vRS_Pagey
  • -Receive: 59
« Reply #127 on: February 05, 2012, 07:57:09 pm »
They look excellent mate, +1 on the alignment, HID bulbs require slight adjustment over halogens, iirc it's something like 1.2 degrees!
Offline WT007
« Reply #128 on: February 05, 2012, 07:59:13 pm »
These are the finished result after being setup by a garage
Offline apples12
« Reply #129 on: February 05, 2012, 08:10:17 pm »
um that beam patterns hideously wrong...
kickups on the far right and far left shouldnt really be that high...
open up the back cover of the headlight and look around where the bulb goes in and you should see some levers which adjust the shield so you can flatten the cut off better...
MK6 GT TDI  - CW - LUX pack
GONE
hugh jass
« Reply #130 on: February 06, 2012, 06:11:52 pm »
Me too. Fitting them and then appointment with MOT man :happy2:
  I nearly bought the LHD ones :signLOL: :signLOL: :signLOL: That would have been expensive.
Offline WT007
« Reply #131 on: February 06, 2012, 09:00:53 pm »
hugh jass would you be so kind to take a pic of your beam pattern when there set up and post it pls  :happy2:
hugh jass
« Reply #132 on: February 07, 2012, 09:13:02 pm »
 For you anything  :happy2:
Offline reflex11
« Reply #133 on: February 29, 2012, 08:50:50 pm »
here's a easy video to follow if anyone is thinking of doing it DIY
note: I might have to buy some hella lights they look great..
hugh jass
« Reply #134 on: March 01, 2012, 07:02:57 am »
 pARSElforce :stupid: managed to mangle my lights into very small pieces.
  New ones on the way this week :popcornsoda:
