Author Topic: Central locking query please help  (Read 1820 times)
Offline imprezzaworks
« on: September 15, 2020, 07:18:14 pm »
Hi guys. Doing a favour for a mate and her 57 plate golf 5 door she's just bought.
Had it motd and failed on a few things. One of which was both wing mirror indicators not working. Popped to the local scrapyard and the right one works fine, passanger not so.
Anyway. The passanger from door doesn't lock, window doesn't work, mirror doesn't work too. Been to our local auto electrician and he's recommending replacing the passanger Central locking motor. Which is a pain as door skin off?
I'm hoping this issue solves all the problems. I noticed the wiring loom has black tape all over it, I'm assuming someone has had a good before, and also assume it's been checked.
Thanks guys
Offline GVK
  • -Receive: 68
    • GVKmotorsport
Re: Central locking query please help
« Reply #1 on: September 15, 2020, 07:47:47 pm »
Wouldn't have thought the door motor would affect the other failures?
Check out the Humble mechanic's video before you fit the door lock theres a couple of good tips on there that are not obvious.
I'd be checking under the tape, you will probably find the fault regarding the mirror and window under there.
« Last Edit: September 15, 2020, 07:54:44 pm by GVK »
« Reply #2 on: September 15, 2020, 07:53:07 pm »
Thanks mate. I'm assuming he will have checked the wiring there. Will call him tomorrow to double check.
Offline titchy
« Reply #3 on: September 16, 2020, 12:36:10 pm »
Mirror indicators are not an mot failure
« Reply #4 on: September 16, 2020, 06:40:57 pm »
Side repeaters are
The lock didn't solve the problem. Taking it some where else who thinks it's the loom.
Offline chimp400
  • -Given: 46
« Reply #5 on: September 17, 2020, 06:40:13 am »
A few things not working would suggest broken wires in the loom.
Can be hard to spot as it's so tight in there and hard to see internal wire breakage.
« Reply #6 on: September 17, 2020, 08:25:04 am »
Interior door card is off. The outer skin one of the lads in work took off and didn't take him long at all. Can get a working loom local if needed, get on well with the scrappy ha ha.
« Reply #7 on: September 17, 2020, 06:33:01 pm »
What a palava. Been at the auto techs all day. Tested various wires, tried a window motor etc. Still no joy. Seems to think all roads lead to the ccm?.
Offline Adrian 200bhp
« Reply #8 on: September 17, 2020, 06:49:34 pm »
Central locking is certainly a head scratcher!! My drivers door doesnt unlock on the fob but ever yother door does but it locks the same as the others when locked on the fob!! I gave up in the end and just unlock drivers door with the key. Very strange.
« Reply #9 on: September 17, 2020, 07:32:24 pm »
That will probably be the lock module?.
This is an issue I wish I hadn't offered to help with. She bought the car in faith and this issue most certainly has been known about prior. Spoke to her before and when she bought the car she said the door isn't locking. He said, mmm it did before?!?. Ass hole.
« Reply #10 on: September 17, 2020, 07:46:41 pm »
Taking it to a lad I know who vag com tomo. Why I didn't ask him first I don't know.
« Reply #11 on: September 18, 2020, 06:52:38 am »
Thats what i thought but the driver door locks ok the fob and opens ok with the key.
« Reply #12 on: September 18, 2020, 07:37:20 am »
Just quoted me mate
« Reply #13 on: September 18, 2020, 10:39:00 am »
Sorry mate, pisted on the run. This is is what i meant to post to your reply :
Thats what i thought but the driver door locks ok on the fob and opens ok with the key.
« Reply #14 on: September 18, 2020, 06:21:08 pm »
We are confident it's the ccm module thing. Ordered one with same part number and get it fitted next week sometime.
Fingers crossed 🤞
