Author Topic: Engine/exhaust warning light.....  (Read 4156 times)
Offline candy turbo
Re: Engine/exhaust warning light.....
« Reply #15 on: March 18, 2010, 08:23:28 pm »
i was told you need stage 2+ to stop this with the milltek dp/ cat fitted , cause 2+ cancels the problem which basically your ecu can not detect the cat if its not up to operating temps , so if you do short jorneys after the 8 th one it will bring up the fault light cause thats how the ecu works , thats why i never got the dp/cat and went non res cat back
« Reply #16 on: March 18, 2010, 08:25:32 pm »
no its taken care of with stage 2 revo  :smiley:
« Reply #17 on: March 18, 2010, 08:27:20 pm »
Just to throw a spanner in the works you can run Milltek downpipe and cat with the standard map without any warning lights.  :wink:
« Reply #18 on: March 18, 2010, 08:29:16 pm »
can u ?
« Reply #19 on: March 18, 2010, 08:30:16 pm »
« Reply #20 on: March 18, 2010, 08:32:30 pm »
did not know that as when i put the DP on mine within 300 miles the light came on, but i did have stage one on the car
« Reply #21 on: March 18, 2010, 08:34:40 pm »
Milltek or Blueflame?  :smiley:
Offline candy turbo
« Reply #22 on: March 18, 2010, 08:44:18 pm »
i was told the ecu checks this every 8th cycle and if you dont get the cat to full temp on 8 consectutive jorneys the light will come on !          was nt sure about revo s2 or s2+
« Last Edit: March 19, 2010, 01:12:22 pm by Greenouse »
« Reply #23 on: March 18, 2010, 08:56:09 pm »
Not quite sure where that info came from but irrespective of map my light doesn't come on with a Milltek DP & Cat.  :wink:
« Last Edit: March 19, 2010, 01:12:38 pm by Greenouse »
Saint Steve
« Reply #24 on: March 18, 2010, 09:10:55 pm »
Just arrived back from Mr Hedges. Thanx again mate for looking into the problems so quick.Hope your dinner tastes better then mine does  :sick:
Ive been running standard map with full milltek and no warning errors shown up.
My doing with removing the airbox tracing the air leak, and lean idle which i hazard a guess again running with no airbox would make idle more lean as usual drawing too much air rather then set ammount governed by the oem airbox.
Offline candy turbo
« Reply #25 on: March 18, 2010, 09:14:22 pm »
jim @ jkm
« Last Edit: March 19, 2010, 01:12:52 pm by Greenouse »
« Reply #26 on: March 18, 2010, 09:16:04 pm »
jim @ jkm
I shall edumacate him next time I see him.  :laugh:
Offline micky 32
« Reply #27 on: March 20, 2010, 11:25:55 am »
So when someone goes Revo stage 2+ for example they disable the warning light system? So if you get a faulty lambda sensor, faulty Miltek cat you will never know you have a problem unless at the MOT?
2008 Octavia vRS K04'd , Forge twintercooler, Evoms, Autotech uprated pump, full Milltek exhaust 324bhp on JKM's rollers ;-)
« Reply #28 on: March 20, 2010, 01:01:21 pm »
No,
They fix the lambda settings, but the sensors still work. If you get a low setting through the cat being defunct you will eventually get a CEL light on. :smiley:
