Thanks - really appreciated.
I'm in a huge dilemma at the moment, as I'm re-building the more for interest that for any intention that it'll be a long term keeper (broken spring forces the issue / I've had it 5 years and with the current situation its not getting much use!!)
I was going to go fairly stock and run B3 springs and B4 shocks. Then I read that the B4 can be a bit 'bouncy' and over gassed.
I was toying with the idea of the Eibach pro spring to get a modest drop (maybe 10mm) but have heard that this with the B4 is again a bit bouncy but the Pro spring works well with the B8.
THEN I got on to the Racingline kit but the general reviews suggest that perhaps the spring lets the kit down so I started considering the .:R spring with the Proline spring...
NOW, I have just gone out and measured my ride height (on the good side at the front with no broken spring and no rotten arch!!) and found that with the soggy old suspension I am, at 637mm, a good 30mm lower than what web searching suggests the stock new ride height should be so I certainly want to be getting a lowered kit of some description as it looks just right as it is. The back is the regularly quoted 670mm (660 one side and 675 the other) floor to arch.
Now my preferred method of measuring heights is hub centre to arch to take out the effect of wheel/tyre combo and tyre wear but I can't find anything using that method.
I'm actually now looking at coilovers to get the height / stance I want - I did this on my Mk4 V5 and was very please with the JOM units I fitted but I just don't like the idea of passing off a car with coilovers now as they arent exactly serviceable, although cheap in the first instance.
Going back to the original point, I wonder now if a Mk6 B4 with a Pro spring would be about where I want to be for not tooooooo much £££
Raceland Ultimo coilovers / JOM and FK AK are back on the options list now
