Author Topic: Driver's door sometimes doesn't unlock with the remote (not battery)  (Read 1775 times)
Offline Ytee
Hi all.
My mk5 GTI recently developed a weird and extremely annoying issue. Sometimes (initially it was occasional, now it's most of the time) the driver's door does not unlock along with the rest of the car when using the remote. I need to use the key to unlock the driver's door. All other locks work fine. Car starts and drives normally. When removing the key from the ignition after stopping the engine though, the drivers door doesn't unlock like it used to either, I have to pull the door handle twice.
"Change the remote battery!" I hear you scream. And I have... twice. It helps for a few goes, then it just stops again. It happens with both remotes as well.
If it was consistent, I might think that the remote needs re-registering... but that's the thing... sometimes it works perfectly fine.
Am I right to suspect the the infrared receiver in the car? If so, how easy is that to replace DIY?
Cheers.
Stage 1 '07 Mk5 GTI
Offline FJB
Re: Driver's door sometimes doesn't unlock with the remote (not battery)
« Reply #1 on: November 02, 2020, 03:49:39 pm »
Your drivers door lock module has failed and needs to be replaced or the wiring at the door hinge is broken.
« Last Edit: November 02, 2020, 05:00:42 pm by FJB »
Free £50 credit when you switch to Octopus Energy using this link: https://share.octopus.energy/pearl-marsh-31
Offline Ytee
« Reply #2 on: November 03, 2020, 10:56:51 am »
Yep, makes sense. My garage seems to agree so I'll get that changed. I don't have the daylight time to tackle it myself at the moment sadly... thanks for the tip.
Stage 1 '07 Mk5 GTI
Offline Danthefourwheeler
« Reply #3 on: November 05, 2020, 10:53:55 am »
I've got exactly the same issue and it's been intermittent for a while. Changed the battery and I thought it went away, but randomly every 1 in 20 days or so, it'll happen again.
If you've got any links to parts that need replacing, I'd appreciate it also
Sent from my Pixel 5 using Tapatalk
