Author Topic: Upgrading rear brakes to R32s  (Read 2825 times)
Offline Lewo
« on: November 03, 2020, 10:19:07 pm »
Trying to source parts and seen these calipers on Ebay
https://www.ebay.co.uk/itm/2-NEW-REAR-BRAKE-CALIPER-LH-RH-VW-GOLF-MK5-R32-AUDI-A3-S3-TT-EOS-8J-QUATTRO-3-2/333686351448?fits=Model%3AGolf%7CCars+Type%3A3.2+R32+4motion%7CPlat_Gen%3AMK+V&epid=249584437&hash=item4db141a658:g:CokAAOSwUlxfN80e
Reckon they would be ok? Will be painting whatever I get red anyway.
Or any others and links would be great thanks.
Offline Stupots
  • -Given: 18
Re: Upgrading rear brakes to R32s
« Reply #1 on: November 04, 2020, 10:11:38 am »
You'll need to factor in buying caliper carriers if you go with these.
Offline mjmallia
  • -Receive: 52
« Reply #2 on: November 04, 2020, 10:55:45 am »
The GTI rear carriers are the same as R32/S3 I thought......just the discs wider due to being vented hence the new calipers needed .
The hose and pads are also compatible to my knowledge, but could be wrong
THIS IS IF you are fitting to a GTI that is  :smiley:
« Last Edit: October 23, 2024, 11:55:26 am by mjmallia »
Mike
South Coast
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=dec8hlcgmtng5ik1fe9h3dr38e&/topic,19740.0.html
« Reply #3 on: November 04, 2020, 02:08:40 pm »
Carriers are different and so are the pads.... not sure about the hoses, can't remember
« Last Edit: November 04, 2020, 02:13:25 pm by rich83 »
Offline Lewo
« Reply #4 on: November 04, 2020, 03:34:12 pm »
Cheers, yeah looking for carriers too.
Found these too
https://brakeparts.co.uk/shop/VW/Golf/05-08/Golf%20MK5%203.2%20R32%204X4/Rear%20-%20Brake%20Calipers%20and%20Wheel%20Cylinders
Seem to be different options too  :thinking:
Offline omeydz
  • -Receive: 50
« Reply #5 on: November 04, 2020, 07:22:03 pm »
Ive got used 310mm r32 calipers and carriers for sale. one nearly new caliper which was recently replaced - the other caliper and both carriers need refurb. PM me if interested.
Recently back on the forum! Good to be back
Current Rides
Mazda RX8 231bhp ( very different little rocket lol!)
SOLD
2007 MK5 Golf 1.4 FSI
2007 Golf MK5 GTI DSG
2008 Audi A5 3.0TDI
« Reply #6 on: November 04, 2020, 08:07:49 pm »
The rear hoses are the same or they were when I did them on my gttdi but you will need the carriers
Offline Lewo
« Reply #7 on: November 04, 2020, 08:26:40 pm »
Ended up ordering of brakeparts.co.uk in the end.
looking on Autodoc the hoses are the same.
I just need to decide what pads to get now, standard or 'performance'?
I'm getting the mk7r brakes fitted at the same time.
Any suggestions on what to get?
I've got EBC green on the standard brakes at the mo which are an improvement
Offline LC5F
  • -Receive: 80
« Reply #8 on: November 05, 2020, 06:10:30 pm »
I don't think you need spicy pads - Golf R front calipers pads are nearly double the size of standard Gti ones.
This is Standard R v Standard Gti Brembo's:
Offline Octoparrot
  • -Receive: 102
« Reply #9 on: November 05, 2020, 08:11:57 pm »
The spring clips are different to the normal gti ones as they have a wider gap to allow for the vented disc even though the pads are the same so I believe.  Andrew Chappel ran into this problem in volkswagen driver mag when he upgraded hie ed30 to r32 brakes, in the end he sourced ones for the 3.2 quattro A3 to get the correct ones, something to bear in mind.
Offline Lewo
« Reply #10 on: November 06, 2020, 09:41:08 am »
Lost me with the spring clips?
Cheers LC5F, the mk7r brakes have the oe TWR pads in at the mo so I'll get the same for the r32s I guess.
Offline Octoparrot
  • -Receive: 102
« Reply #11 on: November 06, 2020, 10:19:43 am »
https://www.brakebook.com/bb/mintex/en_GB/PKW/5/5143/18070/applicationSearch.xhtml
Part MBA1679
They clip onto the carriers and the pads slide on them.
Offline Lewo
« Reply #12 on: November 06, 2020, 11:02:25 pm »
Got ya, yes they came with the clipers. Cheers.
Do the rear pads have wear sensors on them, I can't remember as mate fitted them last time?
« Reply #13 on: November 07, 2020, 12:43:22 pm »
No
Offline Lewo
« Reply #14 on: November 07, 2020, 04:15:03 pm »
No
