Author Topic: fans permanently on  (Read 981 times)
Offline ollyb679
  • Newbie
fans permanently on
« on: November 12, 2020, 09:31:01 pm »
i am after some help
i have a mark 5 golf bwa engine in my caddy but my fans are now permanently on as soon as i turn the car on they come on. This started about 2 weeks ago
Offline SalfordParkes
  • Newbie
Re: fans permanently on
« Reply #1 on: November 13, 2020, 01:05:32 am »
I had the same issue with mine got told of multiple garages it was the fan that was the problem turns out it was my thermostat I changed my coolant temperature sensor and then the thermostat and reset the error codes and the fans haven't been on since
Offline akbarirfan
  • -Given: 81
« Reply #2 on: November 13, 2020, 10:13:07 am »
Could it be Thermostat related?
Offline LC5F
  • -Receive: 80
« Reply #3 on: November 13, 2020, 08:23:57 pm »
Coolant sensor - there are 2 on the Gti
First one is pretty easy to get to above the box and drives the dash gauge.
But my money is on: the other one that is in the thermostat housing...this is the ECU sensor - and its a bit painful to get at under intake manifold -if you are going in there, replace the thermostat at the same time.
