Author Topic: Bluetooth  (Read 3233 times)
Offline Pitsmoor Col
Bluetooth
« on: November 16, 2020, 09:49:14 pm »
Hi, new to VW, just got a 2009 Mk5. TDi. 2.0 How do I use the Bluetooth. Many thanks.
Re: Bluetooth
« Reply #1 on: November 18, 2020, 06:21:15 pm »
Depends what header unit  you have and also it the blue tooth module is fitted
Re: Bluetooth
« Reply #2 on: November 18, 2020, 09:31:12 pm »
Hi, many thanks for your reply, I don't know what head unit I have or if there is a Bluetooth module fitted. I suspect there is no module fitted and I will most likely need a different head unit. How can I tell if the head unit Has Bluetooth fitted ?  If I knew how to upload photos I could show one of the head unit.
Offline probedb
Re: Bluetooth
« Reply #3 on: November 19, 2020, 07:00:27 am »
What Andy said, some have no bluetooth, some have bluetooth in the unit (RNS315 for example) while others require an external module.
Re: Bluetooth
« Reply #4 on: November 19, 2020, 08:51:13 pm »
Hi Probedb. Can you tell me what Head unit has bluetooth ? Thank you.
Offline shoaybmakda
  • -Receive: 54
Re: Bluetooth
« Reply #5 on: November 20, 2020, 12:13:56 pm »
the RNS315 has bluetooth built in or you could go down the route of RCD330.
the other option (if OEM is your thing) is getting an RNS510 and getting a bluetooth kit retrofitted (if you go for the 7p6 module this allows you to bluetooth stream your music too).
to see if you have bluetooth module already, you will see a foam module holder underneath the drivers seats and inside will be the module.
Re: Bluetooth
« Reply #6 on: November 20, 2020, 08:12:32 pm »
Thank you I will have a look when I get the chance.
Offline probedb
Re: Bluetooth
« Reply #7 on: November 20, 2020, 10:37:49 pm »
Happy with my 315. Got a factory fit mic, it also has DAB built in and sat nav.
Re: Bluetooth
« Reply #8 on: November 24, 2020, 10:50:50 pm »
Nothing under the seat, if I get a Bluetooth head unit will I need a module as well ?
Offline shoaybmakda
  • -Receive: 54
Re: Bluetooth
« Reply #9 on: November 25, 2020, 01:49:10 pm »
if you get a unit with bluetooth built in then no you won't need a module
Re: Bluetooth
« Reply #10 on: November 25, 2020, 10:20:50 pm »
Thank you.
