Author Topic: RNS-510 AM Radio not working  (Read 12518 times)
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« on: March 21, 2010, 02:55:42 pm »
Just fitted the RNS-510 aerial adaptor lead to solve my speaker problems I was having when using the MDI interface (http://www.mk5golfgti.co.uk/forum/index.php/topic,12499.msg187738.html#msg187738).
Now it's fitted, I can't get AM radio, just interference. FM works as before. It's consistently worked up until now.
Any ideas?
Thanks  :smiley:
Pete
Offline QD MBE
  • -Receive: 102
Re: RNS-510 AM Radio not working
« Reply #1 on: March 21, 2010, 02:57:34 pm »
The AM Aerial lead has come off.
Offline 182_blue
  • -Receive: 54
« Reply #2 on: March 21, 2010, 04:35:47 pm »
check to see if both aerials are connected, oh and what are you listening too an AM  :confused:  :laugh:
Offline ollie288
« Reply #3 on: March 21, 2010, 04:36:18 pm »
+1  :laugh:
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #4 on: March 21, 2010, 04:51:52 pm »
But that would suggest the new aerial adaptor doesn't do its job?  :sad1:
They both were definitely on as I tested it when the unit was out before refitting, I'll triple check though...
+1  :laugh:
 :signLOL: Only comes in handy for FiveLive when I'm in the car after away games/for England games  :happy2:
Pete
Offline mortygttdi
  • -Receive: 146
« Reply #5 on: March 21, 2010, 06:04:12 pm »
swap the plugs round and try that,  1 cable will work on both but the other will only work on the specific one.
Darren
Offline drexel75
« Reply #6 on: March 27, 2011, 09:24:45 am »
I've only recently got my car and hve no AM radio. How easy is it to check the aerial leads? I have an RCD300 in a 2007 Golf GTI. Thanks.
Offline 182_blue
  • -Receive: 54
« Reply #7 on: March 27, 2011, 09:30:32 am »
Checking the lead is easy, getting to it is another matter  :grin:
http://www.r32oc.com/tutorials-guides/18955-rns-510-mfd-install-how-guide-inc-pin-swap.html
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #8 on: March 27, 2011, 12:46:56 pm »
I never fixed this in the end Sean!
I think I vaguely remember swapping the culprit wires at the back of the RNS and I had neither working FM nor AM radio as a result.
In the end I've just lived without AM for the last year which admittedly is a bit of a pain when you're driving back from 150 miles away and there's a 5.15pm kickoff on FiveLive after an away game  :chicken:
Pete
Offline alexperkins
  • -Receive: 99
« Reply #9 on: March 27, 2011, 01:35:22 pm »
If you have VCDS, you can do a diagnostic on the aerials individually to check all is working  :happy2:
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« Reply #10 on: March 27, 2011, 01:57:34 pm »
^ That I do mate. I'll check it out but I don't remember there being errors in the scans I ran around the time I discovered the issue...
Did you get any errors during a VCDS scan Drexel?
Pete
Offline alexperkins
  • -Receive: 99
« Reply #11 on: March 27, 2011, 01:58:32 pm »
It doesnt show as error. Go into Radio then Measuring Blocks and i think its group 8/9/10 youll see itll say Radio Connection 1 - OK
Offline CocoPops
    • Kennet Heath
« Reply #12 on: March 29, 2011, 10:48:29 am »
Did you get this sorted?
I have the same issue.
I had to remove one of the plug covers to get the aerials to fit the RNS510, so it's feasible that mine are round the wrong way.
Means I've got to pull the RNS out again and try switching them over.
So, do I remove the plastic clips (that don't fit the RNS510) or buy the adaptor?
Used to Own: 2008 GTI Ed30 | ITG Intake | Miltek TBE System | Bluefin Stage 2 | 327bhp
On Order: 2017 Golf GTI Performance Pack 5dr DSG
Also own: 2016 Lotus Evora 400
Offline alexperkins
  • -Receive: 99
« Reply #13 on: March 29, 2011, 10:50:54 am »
Id suggest buying the adapter to be fair - it ensures a good connection, and they wont fall off when your driving along.
I bought the adapter and it was defo worth it!
Have you got VCDS lee? If not, I can bring it up when I pick up the downpipe and check its set properly  :happy2:
Offline CocoPops
    • Kennet Heath
« Reply #14 on: March 29, 2011, 04:47:11 pm »
Right,
Just ordered the adaptor from ebay then.
Will give that a whirl.
I've got a HEX+CAN USB lead and VCDS Alex, just learning how to use it again! :) It's been sat in the drawer for the last 2years!  :grin:
