Author Topic: Mk5 gateway problem..  (Read 5020 times)
Offline Paul rumsey
« on: December 05, 2020, 07:54:59 pm »
Hello all,
I have a 2008 golf 1.4 gt.
Bought it as a non runner, gateway ecu had got water in it and has fried it, locked the whole car out, no diagnostics at all.
Bought a secondhand replacement with the same code, car now works, starts and runs fine.
Trouble is I’m having some problems coding it (vagcom) I have various issues but main ones are,
fuel low warning light On dash, even tho it’s half a tank of fuel (I physically checked this)
Tpms light on, I’m assuming the car doesn’t have this at this age,
Steering wheel light.. (I’m hoping this will go off when I drive it, lock to lock doesn’t work)
I’ve been through the coding helper and checked through everything but it’s not working..
Help...
Thanks in advance.
Paul
Re: Mk5 gateway problem..
« Reply #1 on: December 16, 2020, 07:27:48 am »
Did you replace the GW from underneath or from above (under the plastic cover)?  If the latter, I would check the rubber seal as GWs only get wet when that cover is compromised. The cover is under the driver's side wiper linkage, assuming a 1.4 GT shares the GTI's basic layout.
Providing the replacement GW isn't older than the original one, recoding it should be straight forward.  Plenty of info on Google.
