Author Topic: Eibach ARB Settings  (Read 1390 times)
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Eibach ARB Settings
« on: March 22, 2010, 07:02:16 pm »
Can someone just confirm wether i am right or bonkers in thinking the Eibach ARB's (with 2 holes) have 3 stiffness settings.
I am sure i read somewhere that the settings were as follows:
Bolts in bottom holes both sides = Soft stiffness
Bolt in bottom hole one side & top hole the other side = Medium stiffness
Bolts in top holes both sides = Hardest Stifness
Is that correct?
Reason i ask is someone has told me if you do the medium setting your car alignment will be out and will never be able to be tracked straight due the way the bar is held in.
Mine is set on Softest but that is still waaay better than OEM incase your wondering :signLOL:
Carl
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: Eibach ARB Settings
« Reply #1 on: March 23, 2010, 08:34:51 am »
Anybody?
Offline Damian @ DPM
  • DPM Performance
« Reply #2 on: March 23, 2010, 12:52:18 pm »
2 holes = 2 settings
closest in = stiffer
further out = softer
Damian @ DPM Performance
Advertising removed... (for the time being)
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #3 on: March 23, 2010, 12:57:26 pm »
Must have dreamt the medium setting  :signLOL:
Carl  :happy2:
Offline Janner_Sy
  • -Receive: 113
« Reply #4 on: March 23, 2010, 01:01:00 pm »
i tried mine on the "medium setting(ie one side on the inner hole the other on the outer) never noticed any tracking issues but i only did it for the one wekend before changing to my current front soft rear stiff setup
