Author Topic: Help Please  (Read 3657 times)
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Help Please
« on: March 26, 2010, 04:25:25 pm »
Hi Folks.
Had this fault on the car which is causing the Engine Light to come on
Happened yesterday i cleared the fault to see if it came back and it did today
                Address 01: Engine       Labels: 06F-907-115-AXX.LBL
Control Module Part Number: 1Z0 907 115 A    HW: 8P0 907 115 B
  Component and/or Version: 2.0l R4/4V TFSI     0040
           Software Coding: 0203000318070160
            Work Shop Code: WSC 12340 025 411431
1 Fault Found:
001089 - EVAP Emission Control Sys: Incorrect Flow
               P0441 - 002 - Lower Limit Exceeded - MIL ON
             Freeze Frame:
                    Fault Status: 11100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 92441 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:41:18
             Freeze Frame:
                    RPM: 765 /min
                    Load: 20.8 %
                    Speed: 0.0 km/h
                    Temperature: 90.0∞C
                    Temperature: 18.0∞C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 14.224 V
Ross-Tech wiki lists the following
Possible Causes
Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed
Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed
Evaporative Emission (EVAP) Canister Sealing faulty
Pipes between Tank Breathing and Throttle Body leaky/blocked
Possible Solutions
Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
Perform Output Test
Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115)
Perform Basic Setting
Check Pipes between Tank Breathing and Throttle Body
How do i perform a basic setting on the EVAP canister? is that the same as the throttle body alignment? as that was the only thing i could find in the Ross-Tech Wiki
Did the Output test on the N80 valve and it seemed ok so just wanted to do this other test before taking it to the Stealer. Would you believe the car is 2 Days out of Warranty  :sad1: :sad1: :sad1:
Cheers in advance
Carl :happy2:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: Help Please
« Reply #1 on: March 26, 2010, 05:04:49 pm »
Think i may have found the problem. Not sure though but this certainly wont help
Carl
Offline QD MBE
  • -Receive: 102
Re: Help Please
« Reply #2 on: March 26, 2010, 05:45:41 pm »
Thats the culprit.  Mine is broke too, but I have araldited mine with no problems.  A new cannister is pricey too!
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: Help Please
« Reply #3 on: March 26, 2010, 05:52:11 pm »
You can just replace the pipe
It's £8.50 Inc VAT for the breather pipe
Cannister is about £90 if that is the culprit though :surprised:
Carl :happy2:
Offline Janner_Sy
  • -Receive: 113
Re: Help Please
« Reply #4 on: March 26, 2010, 06:20:07 pm »
carl is your car disintegrating. jesus christ.  at least it was a cheap fix
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: Help Please
« Reply #5 on: March 26, 2010, 06:26:02 pm »
Lol it is 3 years old so I suppose things do go wrong.
I've barstewardsised it for now with self amalgam tape.
Will see how it fairs on the drive up north
Carl :happy2:
