Author Topic: Brake vacuum hose  (Read 1894 times)
Offline Danjk
Brake vacuum hose
« on: January 22, 2021, 03:50:17 pm »
Hi guys,
Had some very soft brakes lately and when investigating I found it to be a cracked vacuum hose. I was having some trouble getting it off and pulled so hard it snapped something it was attached to that I cant see from above the engine.
The part number for the bit that broke is:
1 KO 612 071 D
Can anyone tell me what it is that Ive broken, or a part number and is it engine out to replace?  :sad1:
Heres some photos:
Thanks!
« Last Edit: January 22, 2021, 08:12:34 pm by Danjk »
Re: Brake vacuum hose
« Reply #1 on: January 22, 2021, 07:10:47 pm »
Missing pics but sounds like you just need a new one of the part number you quoted.  That's a common piece to fail.  I think it's around £40, and you'll need a little green blanking plug for the little spout.
Offline Danjk
« Reply #2 on: January 22, 2021, 08:13:54 pm »
Hi,
thanks for that! Do you know what the green blanking plug is or what I should try googling?
I have amended the pics,
Thanks man!
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #3 on: January 23, 2021, 09:13:39 pm »
It looks like you broke this piece from the vacuum pump. It comes with the pump and cannot be found separately; https://c1552172.ssl.cf0.rackcdn.com/452615_x800.webp
Offline DBXdarkangel
  • -Given: 18
« Reply #4 on: January 23, 2021, 09:34:06 pm »
Put some tape around it and save yourself £40..  that's what I did and hasn't moved in 4 years.
Offline Danjk
« Reply #5 on: January 27, 2021, 12:48:26 pm »
Thank you, thats exactly it. Il have to find one off a car being broken.
Thanks for all the help guys.
