Author Topic: P13E200: Sensor for internal pressure of cylinder 3, OBD CODE  (Read 2820 times)
Offline deltawing
« on: February 08, 2021, 03:51:31 pm »
I have a MK5 Gti 2006 with a lumpy idle, gets worse when I take the dipstick out or remove the oil cover
Ran it through a OBD scanner and it through up these errors, can anyone make sense of it for me
Particularly
Quote
thank you
Quote
Car Scanner ELM OBD2
DTC report
Selected brand: Volkswagen
============1==============
5699
Raw code: 1643
ECU: 01. Engine control unit
Status: Pending fault present, Validated and stored in non volatile memory
Volkswagen: Please error memory of the electron. Read out ZE
============2==============
8801
Raw code: 2261
Status: Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request
Volkswagen Caddy 2011-2020; Transporter 2020; Crafter 2018 - 2019; Crafter NF 2017 - 2019; Transporter 2010-2019; Amarok 2010-2020; Crafter 2006-2017; Fox NF / Spacefox / Suran 2014-2019; Gol GP 2013-2019; 6R - Polo, 60 / 61 - Polo / Vento, 6RS - Polo Vivo, 63 - Polo Ameo; Polo GP 2014 - 2017; Polo 7 2017-, T-Roc 2018-; Polo G 2018-; Jetta 2011-2017, Jetta USA/ CDN 2007 - 2017, Beetle Cabrio 2014 - 2017, Beetle / Beetle USA / CDN 2011 - 2017, Golf / Golf USA / CDN / Golf Plus / Rabbit USA / CDN / Bora 2008; Golf 6 (VW351/352/359), Golf Plus 2009, Golf 6 NAR(VW351 / 352 / 359, MJ 2010), Touran 2009 - 2010, Golf Variant 2010 - 2013, eGolf 2011 - 2012, Rabbit USA/ CDN 2009, Scirocco 2009 - 2017, Eos 2009 - 2017,Sharan 2011 - 2017,Touran 2011 - 2017,Tiguan 2008 - 2017,Golf Cabriolet 2011 - 2017,Bora 2009 - 2013,Jetta 2009 - 2013; Golf A7 2013-2017, Touran 2015 - 2017, Golf Sportsvan 2014 - 2017, Tiguan 2016 - 2017; Passat 2007-2011, Passat 2011 - 2017, Passat CC 2009 - 2017; Arteon 2017-, Passat B8 / Passat CC B8 2014 - ; CR Touareg 2017 - ; Up 2011-2017; VAG other; Tiguan 2010 - 2017; Touran 2010-2011, New Touran 2010 - 2017: P13E200: Sensor for internal pressure of cylinder 3
Malfunction
Volkswagen Crafter 2018 - 2019; CR Touareg 2017 - : P0DB300: Hybrid/EV Battery Cell Balancing Circuit "B" Range/Performance
============3==============
0895
Raw code: 037F
ECU: 16. Steering column
Status: Pending fault present during this driving cycle, Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory
Volkswagen: Adaptive Cruise Control-E45 Control Panel; GRA / ADR control panel-E45
============4==============
0932
Raw code: 03A4
ECU: 42. Driver door electronic equipment
Status: Pending fault present, Test conditions are met, Validated and stored in non volatile memory, Validated fault present at time of request
Volkswagen: P176400: Transmission temperature monitoring
============5==============
0893
Raw code: 037D
ECU: 46. Central comfort systems module (VW TP2.0)
Status: Pending fault present, Pending fault present during this driving cycle, Test conditions are met, Validated and stored in non volatile memory
Volkswagen: U10BC00: Coding not possible
