Author Topic: Mk5 tdi retrofit gti steering wheel  (Read 1020 times)
Offline Brandon558500
« on: February 15, 2021, 11:49:31 pm »
Managed to get paddle shifters to work and horn but not power steering ? Tried vagcom and steering calibration but ain’t getting anywhere? Can someone give me some specific help
Offline Stupots
  • -Given: 18
Re: Mk5 tdi retrofit gti steering wheel
« Reply #1 on: February 16, 2021, 06:51:04 am »
I had this after doing mine and thought I'd have to undo the entire process, but in the end it was just more effort on the steering calibration that fixed it... so nice when the lights on the dash go out.
I'm assuming this is a Mk5 wheel in a Mk5 (if it's a Mk6 wheel you'll need the updated steering control module and possibly slip ring) and you've driven down the road some so... what did it for me was full lock to lock 3 or 4 times, then I went for a drive around the block (maybe 500 yards) then full lock to lock 3 or 4 ties again and then boom, lights out and power steering back!
Good luck!
« Last Edit: February 16, 2021, 06:55:32 am by Stupots »
« Reply #2 on: February 16, 2021, 09:08:56 am »
Hi. Yes it’s a mk5 wheel in a mk5,  did you use vagcom while calibrating? Or did you manage to get the PS light off just turning the wheel?
Offline Stupots
  • -Given: 18
« Reply #3 on: February 18, 2021, 10:18:02 am »
@Brandon558500 vagcom was not required for calibration
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #4 on: February 27, 2021, 07:40:29 pm »
This can happen if your wheel abs sensor is faulty.. Quite common on mk5s.
Offline Octoparrot
  • -Receive: 102
« Reply #5 on: February 28, 2021, 07:33:42 pm »
Yes quite correct, this happened to me recently so check for abs codes.
