Author Topic: Engine splutters when brakes pumped?  (Read 878 times)
Offline maxamplitude10
  • '07' ED30 Manual 3Dr
« on: March 05, 2021, 06:50:30 pm »
Guys I've just noticed that when I pump the brakes the engine stutters and farts, I assume this is some kind of vac leak but is there a non return valve somewhere in the circuit which could be at fault?
Any direction/ ideas would be very much appreciated
Max
Re: Engine splutters when brakes pumped?
« Reply #1 on: March 05, 2021, 08:19:18 pm »
Yeah there's 2.  One in the vacuum pump to intake hose, and another one in the hose that runs around the back of the engine to the firewall.
I have to say though, if you're stabbing at the brake pedal with the engine idling, it's not unusual for the engine to stutter as it's emptying the servo and heavily loading the intake manifold/vac pump.  If you had a genuine air leak, the long and short term fuel trims would be huge and the brake pedal would need a heftier shove than normal.
Can you hear a hissing noise at idle that goes when you press the brake pedal?  If yes, the brake servo is f'cked.  Quite common and mine's been leaking for years, but haven't got around to changing it.
« Last Edit: March 05, 2021, 08:21:09 pm by Pudding »
« Reply #2 on: March 05, 2021, 10:09:54 pm »
Thanks Pudding yeah I think you may be correct as I was stabbing at the pedal checking on brake pressure sensor fault :happy2:
Cant hear any hissing at idle either....
Cheers Max
