Author Topic: Fitting MFSW Ed.30 instead if MK5 GTI STANDAR SW  (Read 1402 times)
Offline Zahran
« on: March 05, 2021, 08:35:52 pm »
 :driver:Hi all,
 I hope you doing well,
I am sure this question answered before but I can’t find it,
I want to retro fit a multi functional steering wheel from MK5 GTi Ed.30 manual, into my MK5 GTi which is got the standard Steering wheel, is there any step by step article for this?
Kind regards
Magdy
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Fitting MFSW Ed.30 instead if MK5 GTI STANDAR SW
« Reply #1 on: March 05, 2021, 10:57:30 pm »
You will need a multi function steering wheel control module as minimum. Apart from that it's a steering wheel off and on job and then code and clear errors using vcds.
Sent from my VOG-L09 using Tapatalk
Offline Zahran
« Reply #2 on: March 13, 2021, 05:20:03 am »
Hi guys,
I installed the MFSW and control module ended by CH , all working, But bow the steering wheel hard to drive and the lights on even after a short trip driving, any idea?
Offline Octoparrot
  • -Receive: 102
« Reply #3 on: March 13, 2021, 10:19:08 pm »
You need to do the steering angle basic settings and steering limit adaptation procedures with vcds. Follow the links in the first post https://www.mk5golfgti.co.uk/forum/index.php/topic,111188.0.html
Offline Zahran
« Reply #4 on: March 14, 2021, 07:47:20 am »
Thanks all sorted.
