Author Topic: Front drivers side knock  (Read 2495 times)
Offline CarlW
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92229.msg927100.html#msg927100
« on: April 02, 2021, 03:57:17 pm »
Car has developed a knocking noise on the front drivers corner.
It’s only noticeable when going over speed bumps or sometime if taking a left turn at slow speeds.
When the car had its MOT it was noted that there was a misting of oil on the front shock absorber and I was advised it will be okay but will need replacement shortly so I’m guessing this is likely related.
I don’t have a clue about cars myself in terms of mechanical work hence why I’m here as I suspect I will likely need to replace the front shock(s) however I do plan to get this fully checked before I start ordering parts however I would like to prepare myself for the worst if I can.
So I’m looking for suggestions on what is the best replacement shock absorbers for a MK7 14 Reg GTI that retains the DCC facility which I have only just discovered my car has :)
Car is completely standard however open to a drop to take away the arch gap would be a plus if going through trouble or replacing shocks.
Offline Octoparrot
  • -Receive: 102
Re: Front drivers side knock
« Reply #1 on: April 02, 2021, 07:37:14 pm »
I'd check the antiroll bar drop links first before replacing the shocks, they can make a right racket with only minimal play in the ball joints.
