Author Topic: Ignition Coil Puller  (Read 1110 times)
Offline frasermk5
« on: May 07, 2021, 07:13:19 pm »
Can someone provide a link to a good quality ignition coil puller for the MK5 GTI? Mines done 90k and don’t think the coils have ever been lifted so expecting it to be a bit stiff
Offline Hypertuned
Re: Ignition Coil Puller
« Reply #1 on: May 07, 2021, 07:22:00 pm »
Don't let the marketing/sales people persuade you into buying another tool you will rarely use. Just pull up on the coil pack rocking the pack back & forth until it comes loose. It takes you 10 minutes to try first...then if you really can't get them out buy a puller.
https://www.ecstuning.com/b-schwaben-parts/schwaben-vag-coil-puller-tool/019535sch01a/
Sent from my SM-N9750 using Tapatalk
Offline DBXdarkangel
  • -Given: 18
« Reply #2 on: May 07, 2021, 09:26:29 pm »
YouTube is your friend bro
Offline Jb55
« Reply #3 on: May 07, 2021, 09:43:25 pm »
Don’t lever them out with screw driver like in the video  :stupid: use some heavy duty cable ties in a loop to pull them them out
« Last Edit: May 07, 2021, 11:09:16 pm by Jb55 »
Offline Rampage
« Reply #4 on: May 07, 2021, 10:18:19 pm »
I’ve always used the large metal clip that you take off of the air intake hose when removing the engine cover. Just pull up... works like a charm every time
  • -Given: 18
« Reply #5 on: May 08, 2021, 09:21:34 am »
I've done mine many many times using this method. No issues at all.
Offline Hypertuned
« Reply #6 on: May 08, 2021, 09:34:19 am »
I have used this method once when I couldn't do it by hand, works well and is cheap too!
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=04c2ob8vrmml7j0lrqo5sc69qd&/topic,19740.0.html
« Reply #7 on: May 08, 2021, 09:51:07 am »
Just get the tool. So much easier than trying to wrestle with them or mess about with other methods.
