Author Topic: Spark Plugs  (Read 1959 times)
Offline frasermk5
Spark Plugs
« on: May 07, 2021, 07:37:25 pm »
Do people usually recommend NGK BKR7EIX plugs for the MK5 GTI? Thinking of these and the R8 coils from awesome GTI but not sure the r8 coils actually do anything, more just for styling?
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
Re: Spark Plugs
« Reply #1 on: May 08, 2021, 02:01:41 am »
NGK (1675) PFR7S8EG are the current OE plug, but they are platinum center core_have a 1mm center core_and have a 0.031"(0.8mm) gap. They work fine.
NGK (2667) BKR7EIX are highly used; they are Iridium center core and platinum coated ground electrodes_have a 0.6mm center core_and also have a 0.031" (0.8mm) gap. They may last longer than the platinum center electrodes. But if you do not plan on running the plugs more than 50k miles...it shouldn't matter which of these two you use.
NGK (4853) PFR7B are a good choice for high boost, but this is only due to them having a factory reduced gap of 0.7mm. They too are a 1mm platinum center core and come with a 0.027" (0.7mm) gap.
R8 coils; are a 5.31 Mohm resistance coil...not meant for a long duration during ignition. OE are 3.3 Mohm (refers to secondary winding resistance) and are meant for longer duration ignition and quick recovery of voltage. The longer duration is meant to provide better fuel burning during combustion.
« Last Edit: May 14, 2024, 02:30:59 pm by ROH ECHT »
