Author Topic: Aerial rubber replace / Aerial removal  (Read 1165 times)
Offline Trav Turbo
  • -Given: 18
« on: May 25, 2021, 10:51:43 am »
Hello all! Has anyone replaced a Aerial base rubber on a 3 door GTi before & know where the aerial wire is located under the headlining & trims to undo the wire to remove the aerial?
Thanks in advance.
Sent from my SM-N950F using Tapatalk
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
Re: Aerial rubber replace / Aerial removal
« Reply #1 on: May 25, 2021, 11:13:14 am »
if you put the rubber aerial base in warm water for a while it become soft enough to slip over the aerial base without removing it.
Offline Trav Turbo
  • -Given: 18
« Reply #2 on: May 25, 2021, 11:20:46 am »
Amazing! Thanks for your help cheers
Offline imprezzaworks
« Reply #3 on: May 25, 2021, 08:34:23 pm »
As above that's how I did mine
Offline Lewo
« Reply #4 on: May 25, 2021, 08:57:34 pm »
Need to do mine as it goes, Ebay for the rubber base?
« Reply #5 on: May 25, 2021, 09:02:03 pm »
Yeah. There about a fiver iirc
