Author Topic: Undiagnosed rattle with video link..  (Read 809 times)
Offline Norfolk Ollie
« on: May 27, 2021, 08:49:26 pm »
Hi there, I've got a rather worrying rattle coming from my engine. I had the cam chain replaced about 15k ago so I wouldn't expect it to that. Also replaced the cam follower and the timing belt has been done since. My mechanic was at a loss when he listened to the noise and said I should get other opinions before he tries to diagnose it. If I can then I'd like to post a video on here to show the noise. Thanks, Ollie.
« Last Edit: May 27, 2021, 09:05:00 pm by Norfolk Ollie »
Re: Undiagnosed rattle with video link..
« Reply #1 on: May 29, 2021, 11:54:03 am »
Does the noise change or go away with more revs and/or load?
I would get a mechanics stethoscope from Amazon and do some probing.  Might be worth also getting an oil pressure gauge kit to check the pressure.  If it's a bit low, the VVT/chain gear will be quite noisy.  The oil pump/balancer assembly is a known weakness on these engines.
« Reply #2 on: May 31, 2021, 08:01:50 am »
Thanks Pudding I'll get one of those stethoscopes and check the oil pressure.
