Author Topic: Wheel valve hole  (Read 2091 times)
Offline k50
Wheel valve hole
« on: March 28, 2010, 09:16:36 pm »
Hi wondering if anyone has any suggestions. Bought a new monza 2 off ebay and have found out it's a factory second due to the valve hole being too small. Anyone know if they can be made bigger? anywhere that could do this? thanks
Re: Wheel valve hole
« Reply #1 on: March 28, 2010, 09:44:11 pm »
Are you sure it isn't meant to have one of the VW specific metal valves?
Offline k50
« Reply #2 on: March 28, 2010, 10:05:00 pm »
Yeah I bought new valves fron VW because of tyre pressure monitors. Garage said hole too small for any type of valve
Offline holepunch
« Reply #3 on: March 28, 2010, 10:06:38 pm »
I believe the tyre pressures are measured using the roation of the wheel and not a sensor in the valve?
Offline gillm
« Reply #4 on: March 28, 2010, 11:46:02 pm »
me too . otherwise aftermarket alloys would cause all sorts of issues on mk5's . and i have not had any !
west tuned gt28 @ 340hp
Offline DanGB
  • Different
« Reply #5 on: March 30, 2010, 02:02:20 pm »
thas correct, it uses the ABS for the TPMS.
Seat Leon Mk2 TFSI sport 4WD sleeper - Breaking
Buld thread: http://www.mk5golfgti.co.uk/forum/index.php/topic,45377.0.html
Offline winrya
« Reply #6 on: March 30, 2010, 02:15:25 pm »
There are 2 types of monza 2's.  The difference is the valves sizes so you may find you've just got the wrong ones
