Author Topic: Boost pressure regulation control  (Read 2801 times)
Offline MKMike
« on: June 02, 2021, 02:47:21 pm »
Hi,
Has anyone got experience with the below codes?
I've recently had a new turbo pipe and seal fitted by VW but the issue is still there. Will be calling them again when I get the chance. The indi that got me these codes said they need to get someone in to smoke test it.
  • -Receive: 692
Re: Boost pressure regulation control
« Reply #1 on: June 04, 2021, 11:54:59 pm »
Clear the codes first and see what comes back because the first code could be related to the recent work.
If not, first code is usually a split diverter valve or worn out boost O rings.  Failing that, N75 valve not working or worn turbo/wastegate penny valve.
Second and third codes are related to the EVAP system.  Usually the N80 solenoid stuck open causing a lean condition. Sometimes a new carbon can is also required to shift the third code.
