Author Topic: rs4 pres?sure reg  (Read 4532 times)
Offline gillm
rs4 pres?sure reg
« on: March 28, 2010, 09:56:43 pm »
whats the pros and cons of this ?
where does it fit and what does it cost ?
west tuned gt28 @ 340hp
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: rs4 pres?sure reg
« Reply #1 on: March 29, 2010, 05:50:44 am »
i saw on the american forum, that the price range is 70-100USD.
Pros:
 might solve the dip many have above 5k rpm, i for one has ordered one  :wink:  :love:
Cons:?
System isn't up for the extra pressure???  :confused:
Over the top mod list ;o)
« Reply #2 on: March 29, 2010, 02:22:54 pm »
Pro's
It enables the rail to meet requested in the remap. REVO specifies 132.5bar and the stock system tends to run short of this
The low pressure "in-tank" pump pressure doesn't fall as much as when the OEM valve is used
Con's
Need to take off the manifold to fit unless you haz pixie fingers with double jointing.
  • -Given: 243
  • -Receive: 154
« Reply #3 on: March 29, 2010, 02:45:49 pm »
Pro's
Con's
so in reality no cons then?  :wink:  :happy2:
Offline fuscobal
  • -Receive: 27
« Reply #4 on: March 29, 2010, 06:32:52 pm »
My mechanic installed it without taking out the manifold but he has pixie fingers and also had to "improvise" a key to fit there !
Mk5 GTI 6MT - Revo stage 3
Offline jonnyc
  • Herrooooo!
« Reply #5 on: March 29, 2010, 06:59:01 pm »
Seems to lower the LPFP duty cycle % too which on anything larger than a K04 is only a good thing! Well worth doing if the inlet manifold is off..
  • -Given: 243
  • -Receive: 154
« Reply #6 on: March 29, 2010, 07:06:01 pm »
i hope it might help me with this dip:
Offline gillm
« Reply #7 on: March 29, 2010, 07:35:54 pm »
cool i will order 1 up then . manifold will be coming off soon anyways
Offline jonnyc
  • Herrooooo!
« Reply #8 on: March 29, 2010, 07:36:47 pm »
For the cost its a no brainer  :smiley:
« Reply #9 on: March 29, 2010, 08:07:23 pm »
Bl00dy hell Danish, that ain't no dip that's a black hole :surprised:
Offline Janner_Sy
  • -Receive: 113
« Reply #10 on: March 29, 2010, 08:22:54 pm »
what is this, is it the low pressure fuel sender.  if it is i had it rplaced on mine under warrantee, and was a pain in the ass to do.
is his likely to fix these dips or is it just another mod that miht fix it??
  • -Given: 243
  • -Receive: 154
« Reply #11 on: March 29, 2010, 08:38:11 pm »
tell me about it, but we are working on it. any ideas??   :confused:
« Reply #12 on: March 30, 2010, 12:23:08 am »
Any logs for me?
Looks like either fuel cut, timing pull or even the dreaded onset of compression surge, but as for the cure, that's a different matter!
You are on a stock GTI block from what I remember and so the compression ratio will be 10.25:1 rather than the 9.8:1 of the ED30 block. This may also account for the bigger dip as some ED30/Cupra/S3 guys get this dip, but to a lesser extent. I'm sure you can get gasket sets to reduce the compression ratio by a few points, which may help if that is what it is and it would be less expensive than just opting for lower compression pistons to try and get rid of it. There are tuning options, but I'm assuming that you are already covering that side of things.
HTH :happy2:
Offline micky 32
« Reply #13 on: April 05, 2010, 04:06:08 pm »
I'm on the standard GTI block higher compression with a KO4 and not experiencing the flat spot at all
2008 Octavia vRS K04'd , Forge twintercooler, Evoms, Autotech uprated pump, full Milltek exhaust 324bhp on JKM's rollers ;-)
Offline Janner_Sy
  • -Receive: 113
« Reply #14 on: April 05, 2010, 04:14:53 pm »
did you here what happened to harrys vRS mickey.
