Author Topic: Brake Disc Size  (Read 1964 times)
Offline frasermk5
Brake Disc Size
« on: June 05, 2021, 04:24:51 pm »
What brake disc size should I go for on my 2008 MK5 GTI? Just an everyday runabout with a few subtle mods such as cold air intake, GSF recommend 288mm on the front and 255 rear? Does this sound about right? Going for the Brembo’s BTW.
Cheers!
Offline Clarkj93
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=ffff88apt9o9hppfe0t2iadrs6&/topic,131272.0.html
Re: Brake Disc Size
« Reply #1 on: June 05, 2021, 04:48:20 pm »
Those may fit but they're not the size the gti is meant to use. It's 312 up front and the rear from memory is around 282 I believe? And yeah the brembo discs are very good quality.
The smaller discs will mean reduced braking performance.
Re: Brake Disc Size
« Reply #2 on: June 05, 2021, 06:13:47 pm »
Just gathering parts to do this myself actually.  312mm up front and yeah, 280ish at the back.  I went with the ATE discs & pads from ECP, since that is the same brand as the calipers.  And 2 cans of Bosch ENV6 brake fluid for a full flush  :smiley:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=ffff88apt9o9hppfe0t2iadrs6&/topic,19740.0.html
Re: Brake Disc Size
« Reply #3 on: June 05, 2021, 10:43:33 pm »
312mm front
282 or 286mm rear. You can use either.
Offline momo.mk5GTI
Re: Brake Disc Size
« Reply #4 on: June 07, 2021, 12:02:55 pm »
Hello guys, i have a pair perfored dics from my old tdi. I looked the number and there s 280mm i dont know if they will fit at my gti at rear. Is it matter 2mm or must to try if there is the same?
Re: Brake Disc Size
« Reply #5 on: June 07, 2021, 03:56:24 pm »
What thickness are they? You might get away with them
Offline momo.mk5GTI
Re: Brake Disc Size
« Reply #6 on: June 07, 2021, 06:32:01 pm »
Link to all the info
https://www.bremboparts.com/europe/fr/catalogue/disc/09-9167-1X
Re: Brake Disc Size
« Reply #7 on: June 07, 2021, 10:57:00 pm »
They won’t fit too thick. GTI discs are around 12mm
Offline momo.mk5GTI
Re: Brake Disc Size
« Reply #8 on: June 08, 2021, 09:01:24 am »
Thanks mate 🤝
