Author Topic: Replacing window regulator assembly.  (Read 3959 times)
Offline Lewo
« on: June 17, 2021, 08:04:31 pm »
Just looked on Pelican parts but due to being incapable of taking in information at the mo lol I just wanted to check if I need to remove the door panel and remove the motor as well as the door skin to fit the new regulator assembly?
Cheers.
Offline Carpy25
Re: Replacing window regulator assembly.
« Reply #1 on: June 17, 2021, 09:50:40 pm »
Yes you can’t disconnect the motor
Link here
Rob
Offline Lewo
« Reply #2 on: June 17, 2021, 10:28:45 pm »
Cheers, just saw that after I posted.
Just need to sort the door skin issue before I tackle this lol.
Offline joannsabki
  • Newbie
« Reply #3 on: September 14, 2022, 05:54:27 pm »
Yes, you have to do all these steps, unfortunately. The situation is much more complex than it seems. The video shared by a participant of this forum is really useful, but the process is complicated. I could not do all this work by myself. Everything started from removing the sun shades for car to the engine, door skin, etc. So, if you make a wrong step, you can end up in a very bad situation and make everything worse. That's why I would still recommend you to ask for the help of a specialist. He will do all this work for you with great care, and thus you will not have any trouble.
« Last Edit: September 19, 2022, 12:02:01 pm by joannsabki »
