Author Topic: RNS 310 - Adding cheap China Bluetooth (aux)  (Read 3404 times)
Offline Stamanatic
« on: June 20, 2021, 07:19:44 pm »
Has any had any luck fitting one of these to an RNS 310?
In VCDS I have both the normal front aux monitoring enabled and the cd changer/usb monitoring which is what this device is.
I also have Media Player(2E) enabled in the canbus installation list for good measure
I also took apart the harness to see if the pins matched those pins referenced on the RNS 310 diagram, and pins 1,2,7 do match the diagram see below:
About to give up and just continue using the front aux in but seeing if anyone ever got those bluetooth modules to work that piggy back off the rear aux pins, I can also see the Bluetooth module on my phone but when I hit the media button on the front of the RNS 310 I no devices available, if I plug in my front aux cable then that allows me to switch between the SD and CD, so the monitoring for the front aux works as intended but the rear monitoring which I have enabled too doesn't seem to have any effect.
