Author Topic: Poor idle  (Read 1540 times)
Offline Octoparrot
  • -Receive: 102
Poor idle
« on: July 02, 2021, 10:30:02 pm »
My car has suddenly started idling poorly, got a code from vcds of p2279 air leak, does this sound like a failed pcv valve?
Re: Poor idle
« Reply #1 on: July 02, 2021, 11:46:33 pm »
That is certainly a potential culprit. If the PCV valve is stuck open, it will definitely cause an air leak.
Offline JoshB
Re: Poor idle
« Reply #2 on: July 11, 2021, 08:56:04 am »
I think P2279 is to do with your diverter valve. Does it pull alright?
Getting too old for this...
Offline GVK
  • -Receive: 67
    • GVKmotorsport
Re: Poor idle
« Reply #3 on: July 11, 2021, 08:59:11 am »
is intake air leak so check the PCV, the PCV gasket and the brake servo pipe work. Spray WD40 at the suspected leak and the engine will suck it in raising the idle.
Offline JoshB
Re: Poor idle
« Reply #4 on: July 11, 2021, 09:02:15 am »
Offline Octoparrot
  • -Receive: 102
Re: Poor idle
« Reply #5 on: July 11, 2021, 11:35:55 am »
Well I deleted the code and it hasn't come back, the car ran fine all this week but I have changed the pcv and gasket just in case. The pcv was the original but seemed to be working fine when removed. Odd  :thinking:
Offline GVK
  • -Receive: 67
    • GVKmotorsport
Re: Poor idle
« Reply #6 on: July 11, 2021, 01:00:22 pm »
it's fixed, carry on :P
