Author Topic: Remote Locking Not Working On Any Key?  (Read 1648 times)
Offline JTI
  • -Given: 19
« on: July 20, 2021, 09:26:29 pm »
Hi, my car has stopped locking remotely using the key and I am having to manually lock/unlock it each time.
I have tried a few of the ways known to recode the key but nothing seems to work. I noticed today when trying a method using the spare key that I couldn't remote lock with that key either. Is this a sign of a problem with the car itself? Locks fine when using the lock/unlock internal button on the drivers door.
Thanks.
Offline Kierandewberry21
Re: Remote Locking Not Working On Any Key?
« Reply #1 on: July 20, 2021, 09:28:12 pm »
Check the fuse on the side of dash on driver side
It’s a 20amp I can’t remember the exact one
« Reply #2 on: July 20, 2021, 09:28:40 pm »
Mine does it sometimes and I take the fuse out wipe it put it back in and it starts working lol
Offline JTI
  • -Given: 19
« Reply #3 on: September 10, 2021, 10:44:37 am »
I'm still having this problem, have tested all fuses today and no problems.
Any ideas where I go from here? I understand there is a central locking ECU, is this the next port of call?
« Reply #4 on: September 10, 2021, 11:48:09 am »
Yeah a fault code scanner should pick up any issues in the alarm/CL/ccm (Comfort Control Module), if any present.
Have you disconnected the battery recently?
I find with this car, pulling the battery and reconnecting it within the space of 5-10 mins causes quirks with the Central locking interface.  Such as the windows not remembering one touch, one touch only working on one side, only 1 door unlocking (driver's side usually), keyfobs not working etc.
When that happens I pull the battery for at least an hour and it all comes good again.  It may not solve your problem but it's worth a try.
