Author Topic: Key fob fubar  (Read 1478 times)
Offline Dopey
Key fob fubar
« on: July 26, 2021, 07:20:59 pm »
It locks and unlocks manually and starts, but the remote isn't working and no led is coming on pressing the buttons, so I guess it's fubar, who are replacing key fobs apart from dealers? thanks
Offline Octoparrot
  • -Receive: 102
Re: Key fob fubar
« Reply #1 on: July 26, 2021, 07:31:14 pm »
Have a ring around local car locksmiths, they're usually much cheaper than the dealer.
Re: Key fob fubar
« Reply #2 on: July 26, 2021, 07:37:18 pm »
have you tried changing the fob's 2032 battery and reprogramming the fob?
Offline Dopey
Re: Key fob fubar
« Reply #3 on: July 26, 2021, 08:14:18 pm »
How do you reprogram it then?
Re: Key fob fubar
« Reply #4 on: July 26, 2021, 08:30:02 pm »
If you have another working key fob then you could what  vRStu posted in the past:
Using a spare key switch the ignition on.
Insert the key to be programmed into the driver's door lock.
Manually lock the driver's door using the key.
Press the Lock or Unlock button on the fob once.
Wait for a least one second.
Press the Lock or Unlock button on the fob twice.
The vehicle horn will sound to indicate correct programming.
If no spare fob then it's probably a professional (dealer or locksmith) job for coding.
Offline Dopey
Re: Key fob fubar
« Reply #5 on: July 26, 2021, 08:37:26 pm »
Thanks for that
Offline imprezzaworks
Re: Key fob fubar
« Reply #6 on: July 26, 2021, 08:40:59 pm »
Pop a battery in it and see how you get on. I've replaced batteries in my key with out reprogramming with no issues.
Offline Dopey
Re: Key fob fubar
« Reply #7 on: July 26, 2021, 09:00:36 pm »
She said she replaced it already, and it worked for a few days, then stopped again, I will try resetting it first, then the battery
Re: Key fob fubar
« Reply #8 on: July 26, 2021, 09:02:29 pm »
Buy a decent battery if you haven't.
Offline Dopey
Re: Key fob fubar
« Reply #9 on: July 27, 2021, 02:19:49 pm »
The key fob is now working, I took it apart, cleaned the board with IPA and put a new battery in, I have just tested it, and its working fine now
Looking on youtube, I see when you lock it, the indicators flash, and you get a small beep as an indicator that it's locked, mine is not doing that, Is that just the usa or is that meant to be for UK cars also, If it's how do I go about setting that up, I can't find it in the book any place
Re: Key fob fubar
« Reply #10 on: July 27, 2021, 04:23:52 pm »
you'll need to code it in with vcds or the like to get the chirping sound when you lock the car.
Offline Dopey
Re: Key fob fubar
« Reply #11 on: July 27, 2021, 06:01:07 pm »
Ok I have an icarsoft 3.0 yaws, but because I just got the car I don't know how to use it, can I do it with that do you know?
Re: Key fob fubar
« Reply #12 on: July 27, 2021, 07:54:23 pm »
I'm only familiar with vcds so hopefully someone else could help you with this.
