Author Topic: My ED30 runs better on stock map instead of GIAC 305bhp  (Read 4225 times)
Offline Nickyboy
  • 2007 ED30 in Grey
« on: March 29, 2010, 04:35:56 pm »
With the PUMP mode selected (305) the turbo is intermittent, taking foot off the gas then back on sometimes help, but I can't be bothered with that all the time.
So I flashed the stock map back on, and the car drives normal. Sure, it's not as fast when in boost, but the car at least has a personality then. Turbo works when it should.
Few questions though, is it normal for the boost to have 2 stages? It will turbo around 2.5k but then a second wind at 5k.
Does the boost work more in the higher gears? With the 305 map on, the boost in second gear isn't as powerful as say 4th.
I have given up driving like it's a VTEC i think, took some getting used to, am used to no power until 6k RPM.
Re: My ED30 runs better on stock map instead of GIAC 305bhp
« Reply #1 on: March 29, 2010, 04:39:09 pm »
power at 6k is all wrong should be around 2.5k ish
Offline Nickyboy
  • 2007 ED30 in Grey
« Reply #2 on: March 29, 2010, 04:40:44 pm »
Yeah I feel the grunt at 2.5k and another surge later on.
« Reply #3 on: March 29, 2010, 04:41:39 pm »
no it should pull nice and hard from 2.5k
Offline Nickyboy
  • 2007 ED30 in Grey
« Reply #4 on: March 29, 2010, 04:42:43 pm »
Is the boost dependent on how much throttle you're giving it?
« Reply #5 on: March 29, 2010, 04:48:41 pm »
do you know any one near you with vag com? it needs taking out and testing if you ask me as it should pull hard in all gears, i dont have giac map i have revo but i think one or 2 people on here have the same map as u so hang on for them to speak up
Offline Nickyboy
  • 2007 ED30 in Grey
« Reply #6 on: March 29, 2010, 04:49:47 pm »
Cheers buddy. I will ask the local forums for VAG COM.
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #7 on: March 29, 2010, 05:19:02 pm »
in stock mode mine used to boost hard, then around 4500-5500 used to give another slight kick.
It sounds like with your map its showing a component as being faulty maybe that isnt noticeable with the stock boost.
Offline QD MBE
  • -Receive: 102
« Reply #8 on: March 29, 2010, 05:27:59 pm »
stock all the way.............. :happy2:
Offline jonnyc
  • Herrooooo!
« Reply #9 on: March 29, 2010, 06:28:41 pm »
GIAC has lower boost request than Revo so the second kick you feeling is simply due to stock like boost delivery which means the power and torque curve is very linear..
Also the reason for the less boost feeling in the lower gears is due to GIAC keeping the stock torque limit in the first two gears..
Offline Nickyboy
  • 2007 ED30 in Grey
« Reply #10 on: March 29, 2010, 08:18:29 pm »
Would there dash show any warning lights if there were any error codes to check?
Offline scotta
  • Edition 30
« Reply #11 on: April 02, 2010, 10:32:15 am »
Keith @ washsshop (on here) has got GIAC on  his ED30 - he might be able to help tell you how the map pulls.
Certainly with my bluefin it pulls HARD from 2500 right round to about 7000 with no peaks or troughs.
Where are you based mate?
Offline Nickyboy
  • 2007 ED30 in Grey
« Reply #12 on: April 02, 2010, 11:41:32 am »
near inverness mate. I have ordered a revision d dv in case mine is split, i get a hissing noise and car has done 27k, alot of that mapped.
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #13 on: April 02, 2010, 12:57:36 pm »
Hissing noise when the car is hot and stationary coming from the front of the car?
Offline Nickyboy
  • 2007 ED30 in Grey
« Reply #14 on: April 02, 2010, 01:38:55 pm »
no mate, out on the road with the foot down.
