Author Topic: Check engine light and battery light on after jump start  (Read 755 times)
Offline Adams
  • Newbie
« on: August 14, 2021, 07:47:09 pm »
Hi all,
I have been having this issue lately when I went away for 6 months and my battery drained to 0.
Had my car jump started and ever since I am seeing the CEL and Battery light.
These only appear when key in first position.
See below the results of the OBD scanner.
DETAILED ECU INFO
ECU info obtained with Carista 610099 for iOS:
VIN: WVWZZZ1KZ6W107042
Engine
Part #: 03G906016CB
Component: R4 1,9L EDC 0000
Software version: [none]
ASAM/ODX identifier: [none]
Coding: 72 (decimal)
Fault codes:
17055 Glow Plug/Heater Cylinder 1 (Q10) circuit, electrical Fault in Circuit
17056 Glow Plug/Heater Cylinder 2 (Q11) circuit, electrical Fault in Circuit
17057 Glow Plug/Heater Cylinder 3 (Q12) circuit, electrical Fault in Circuit
17058 Glow Plug/Heater Cylinder 4 (Q13) circuit, electrical Fault in Circuit
ABS
Part #: 1K0907379AA
Component: ESP FRON
Coding: 21121 (decimal)
Fault codes:
00287 Right Rear Wheel Speed Sensor (G44)
Back-up camera
[ECU not present]
Airbags
Part #: 1K0909605R
Component: 38 AIRBAG VW8
Coding: 13112 (decimal)
[No fault codes]
Power steering
Part #: 1K2909144K
Component: EPS_ZFLS Kl.5
Coding: [none]
Fault codes:
00778 Steering Angle Sensor (G85)
Central electronics
Part #: 3C0937049D
Component: Bordnetz-SG
Coding: E4890F2700041800001400001400000000087B075C (hex)
[No fault codes]
Body/convenience system
Part #: 1K0959433AK
Component: KSG
Coding: 00D802087F2D8C0D485BC69010CC (hex)
Fault codes:
01135 Interior Monitoring Sensors
00323 Vehicle Inclination Sensor (G384)
01134 Alarm Horn (H12)
Driver's door
Part #: 1K0959701E
Component: Tuersteuergeraet
Coding: 52 (decimal)
[No fault codes]
Front passenger's door
Part #: 1K0959702K
Component: Tuer-SG
Coding: 692 (decimal)
[No fault codes]
Steering wheel
Part #: 1K0953549AF
Component: Lenksäulenmodul
Coding: 12 (decimal)
[No fault codes]
Heater & air conditioning
Part #: 1K0820047DP
Component: Climatic PQ35
Coding: [none]
[No fault codes]
Auxiliary heater
Part #: 1K0963235E
Component: PTC-Element
Coding: [none]
Fault codes:
00361 Heating element for additional heating system (Z35)
Radio
Part #: 1K0035195B
Component: Radio BVX
Coding: 40400 (decimal)
[No fault codes]
Instrument cluster
Part #: 1K0920962GX
Component: KOMBIINSTRUMENT
Coding: 3403 (decimal)
[No fault codes]
Immobilizer
Part #: 1K0920962GX
Component: IMMO
Coding: [none]
[No fault codes]
CAN network gateway
Part #: 1K0907530F
Component: Gateway
Coding: 3D0F0B40070003 (hex)
[No fault codes]
Obtained with Carista 610099 for iOS.
Download app: https://itunes.apple.com/app/id954363569
Facebook: https://www.facebook.com/caristaapp
I my battery seems to be fine, alternator also charging, checked the 200 AMP fuse all fine. Cleaned the connectors etc, done the usual troubleshooting.
The car is charging fine so I am not too sure what is going on. This does not even appear as a code yet I am seeing these codes when my key is in first position.
Any tips on how to get this cleared/ troubleshooted? Thanks!
Offline Adams
  • Newbie
Re: Check engine light and battery light on after jump start
« Reply #1 on: August 14, 2021, 07:48:52 pm »
I have to add that I thought maybe I have a drainage issue as I have changed front bulbs and interior ones as well, but from my results it seems that it has nothing to do with drainage (2.5-2.7 A while unlocked).
