October 02, 2024, 03:40:32 pm
All Things Mk5
Technical Workshop
HELP!! screw dropped into IM (MK5 GTI)
Topic: HELP!! screw dropped into IM (MK5 GTI) (Read 988 times)
syamonz
Newbie
-Given: 0
-Receive: 0
September 09, 2021, 03:20:15 am »
hi
i was trying to tighten the screw on my boost tap when my car was on without know the screw would get sucked in. i was being an idiot and thought a small screw wont do anything. i drove for 15 minutes fine. stopped for a bit and rev the engine and it started misfiring? expensive fix or sell? or engine replacement
pudding
Global Moderator
Just look at my post count
-Given: 2
-Receive: 685
Re: HELP!! screw dropped into IM (MK5 GTI)
Reply #1 on:
September 09, 2021, 11:28:05 am »
If you are lucky, the screw might be jammed in an intake runner flap, but more likely it got into the cylinder and might have bent a valve.
Maybe get a cheap borescope from Amazon and probe it in there through the intake temp sensor hole?
Octoparrot
Won't Shut up.
-Given: 8
-Receive: 100
Reply #2 on:
September 09, 2021, 12:44:39 pm »
Or whip out the spark plugs and use a borescope to look in each cylinder.
All Things Mk5
Technical Workshop
