Author Topic: The best HPFP out there for mk5 gti 2lt Turbo  (Read 2397 times)
Offline staticlupo_
  • Newbie
« on: September 23, 2021, 08:30:02 pm »
I bought an engine for my mk5gti, the engine has a hybrid turbo. Im looking for 360bhp so need the most reliable and best  HPFP internals?
« Last Edit: September 28, 2021, 03:56:07 pm by vRSAlex »
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=ns44ltiaa77kht072spj7ud28m&/topic,19740.0.html
Re: The best HPFT out there for mk5 gti 2lt Turbo
« Reply #1 on: September 24, 2021, 08:56:54 am »
If you want 100% reliability and no guess work, get a LOBA pump.
« Reply #2 on: September 25, 2021, 11:19:32 am »
The Loba chews through cam followers, as does any pump with stronger spring than stock. For that reason I would choose VIS for value, and Integrated Engineering for long term reliability.
Offline colesey
  • -Receive: 89
« Reply #3 on: September 28, 2021, 01:53:14 pm »
I initially chose VIS for price but would recommend them for their great customer service. Ovidiu is very responsive and hands-on.  Also gentle on followers, like Pudding mentioned.
Offline vRSAlex
  • -Receive: 253
« Reply #4 on: September 28, 2021, 03:55:40 pm »
Maybe 5 years or so back, but I have had more Loba failures than any other pump.
VIS flows the best overall.  We supply brand new pumps ready fitted with VIS internals too to make life much easier.
Follow AKS tuning on Facebook
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
Re: The best HPFP out there for mk5 gti 2lt Turbo
« Reply #5 on: September 28, 2021, 05:10:26 pm »
VIS internals owner here. No issues in the two years since it's been in the car.
« Reply #6 on: October 01, 2021, 11:13:39 am »
The VIS are excellent value and easy to fit.  Just need to be careful with the piston seal and tapping the little button follower down to the correct height.....and the correct way round. There instructions show the button tapped upside down.  The little protuded 'nub' needs to face the follower.
The reason I also recommend the IE pump is because they've considered the long term effects of running an unequal shaft diameter.  Their piston shaft is the same diameter top to bottom as per stock as it's stronger. It also uses the stock spring for longer follower life.
So to answer the original 'best hpfp out there' question, it's the IE item.  But erm, it's $999  :surprised:
