Author Topic: Anti shudder valve replaced but fault codes return  (Read 854 times)
Offline jonny RT
  • Newbie
« on: September 30, 2021, 09:46:59 pm »
Evening all .My sons 2008 GT TDI 140 recently had engine light on and terrible shutdown shaking . VCDS codes showed 12547for ASV and fan circuit .Fuse 24 was blown ,replaced but blew again .
ASV replaced with a one from eurocarparts ,an ERA  brand .
Cars been fine for a week but engine light and shaking on shutdown have returned .VCDS  shows 12547 and a fan code again .Fuse 24 is fine .
Is it more likely a wiring issue to the anti shudder valve or the cheap valve from ECP ? If its a wiring fault then the original valve could be ok.
Any help much appreciated .Thanks .
Offline GVK
  • -Receive: 67
    • GVKmotorsport
Re: Anti shudder valve replaced but fault codes return
« Reply #1 on: October 01, 2021, 11:14:07 am »
Do the fans work or is one seized and blowing the fuse?
Sent from my Pixel 4a using Tapatalk
