Author Topic: GVKs Scirocco GT TDi  (Read 26752 times)
Offline mjmallia
  • -Receive: 53
Re: GVKs Scirocco GT TDi
« Reply #30 on: June 27, 2022, 07:43:31 am »
Sounds like a dead release bearing.  Had something similar on my old Lupo GTI
Mike
South Coast
Offline GVK
  • -Receive: 67
    • GVKmotorsport
« Reply #31 on: June 28, 2022, 05:38:13 pm »
Thanks - it's one or the other will find out next week!
Offline GVK
  • -Receive: 67
    • GVKmotorsport
« Reply #32 on: July 05, 2022, 08:47:26 pm »
Just got car back,DMF was toast!! Bits of the springs were floating around the bell housing. All silent now. :pomppomp:
Clutch kit and flywheel, Sachs parts were used.
« Reply #33 on: July 06, 2022, 02:34:39 pm »
Was the DMF 'flushed' or replaced?
Something to watch out for with ours, but I give it beans when I drive it  :grin:
Offline GVK
  • -Receive: 67
    • GVKmotorsport
« Reply #34 on: July 06, 2022, 07:55:07 pm »
New flywheel and clutch fitted mate, my friend says it's 'cos I pull away in 2nd gear  :P
« Reply #35 on: July 07, 2022, 01:28:09 pm »
Ah sorry mate, I misread that as DPF  :doh: :grin:
I must admit, I sometimes pull away in second as well.  It doesn't seem to mind it though  :grin:
I need to get one of those "clutch to start" bypass looms as I hate cranking with no oil pressure on the thrust bearing.
Offline GVK
  • -Receive: 67
    • GVKmotorsport
« Reply #36 on: July 07, 2022, 08:57:13 pm »
 :signLOL: Flush a DMF I thought you'd gone crackers Kev!
Yeah know what you mean about having to press the clutch :stupid:
I've held back on doing the remap, I don't really want to fork out for injectors and fuel pump ideally.
« Reply #37 on: July 08, 2022, 08:51:47 am »
No, same mate.  TBH the 140 feels pretty brisk anyway to be fair.  I've been reading up on it and some folk say remapping the 140 to 170 makes for a punchier engine than the factory 170 as its less laggy.
Offline GVK
  • -Receive: 67
    • GVKmotorsport
« Reply #38 on: August 12, 2022, 05:22:03 pm »
MOT time, failed on 2 anti roll bar drop links and a side repeater inop.
Side repeater is an LED unit £50 from VW dealer!
Pair of drop links from ECP £34 - Had to cut the nuts off with a grinder! :evilgrin:
Offline GVK
  • -Receive: 67
    • GVKmotorsport
« Reply #39 on: August 11, 2023, 11:37:37 am »
Another year another MOT, passed with just advisories on front pads wearing thin and slight play in osf drop link.
We fitted neww links last year, Starline crap from ECP. Won't be getting them again.  :scared:
« Reply #40 on: August 11, 2023, 10:34:32 pm »
Tsk, how could you  :grin:  Lemforder minimum  :happy2:
Good news on the pass though  :happy2:
Done anything fruity with it yet?  Our MK6 is still standard  :grin:  I looked into it and the faff wasn't worth it tbh and too many comments about remaps causing frequent DPF regens.  Not in for that nonsense.
Offline GVK
  • -Receive: 67
    • GVKmotorsport
« Reply #41 on: August 11, 2023, 10:57:33 pm »
No not done anything with it 'fruity' -it does it's regens at weird times, mostly when idling, which shakes the car runs rough, fan on flat out.
Offline GVK
  • -Receive: 67
    • GVKmotorsport
« Reply #42 on: October 30, 2023, 11:23:10 pm »
2009 Scirocco 2.0 TDI once in a blue moon I get a beep and ESP fault on centre dash. Only does it on initial start up over night like I say very random. No ESP/ABS lights stay on when it does it. No fault codes (checked on VCDS and OBD eleven. Weird one. Any ideas?
Offline GVK
  • -Receive: 67
    • GVKmotorsport
« Reply #43 on: November 25, 2023, 05:23:34 pm »
Gave the Scirocco a bit of a service today. Oil & filter, fuel filter, front pads, aux. drive belt as I've seen what a mess they can do if they fail and go inside the cam belt cover. The Starline front anti roll bar links I fitted last year are both shot so bought a couple from local motor factors and lobbed them on , I say that but we had to cut the top nuts off again with a grinder!
Had a remap from M17 performance recently, up to 180bhp/400nm. Goes well but I think it may have had an ecomap on before judging by the flash counts.
Offline GVK
  • -Receive: 67
    • GVKmotorsport
« Reply #44 on: November 26, 2023, 11:32:35 am »
Since the weather has changed car has also been struggling on cranking especially if i've not driven the car for a day, so I've fitted new battery, hopefully that will stop the ESP warning! Yuasa 096 from Halfords £109.99 FFS!
