Author Topic: Need help in fixing cooling fan  (Read 1866 times)
Offline hamid1998.hk
  • Newbie
« on: October 19, 2021, 12:19:11 am »
I just bought a gti 2011 fsi and run it overheating issue, both fan are not turning on when the car is running but will turn on of brief seconds when it reach to 100'c and when i switch off the car it run in full speed to cool the engine but would not when the engine us run. I did used a obd scanner and found out it has 2 codes for engine and 2 for ac unit.
Engine code
1. VAG fault code P164E
2. p1927 auxiliary engine coolant pump relay open circuit
Air  conditioner
1. VAG fault code 9476885
2. VAG fault code 13701888
I have changed both fans but still no  luck. Can anyone help me
Thanks.
Sent from my SM-A325F using Tapatalk
