Author Topic: I bought back my old mk5  (Read 12887 times)
Offline christii
Re: I bought back my old mk5
« Reply #30 on: June 20, 2022, 03:19:29 pm »
I took the Golf to a track day last Sunday at Kirkistown, which went ok. I had fun but the car wasn’t without its issues, even though I was taking it reasonably easy.
The clutch is doing this thing where it sticks halfway when coming up, only on right hand turns. Which isn’t great for a clockwise circuit. I know what the issue is, I think.
The output shaft in these gearboxes start to get play in them. There is a shim kit which can take the play out. I’ve tried fitting the kit but there isn’t enough play in the shaft to fit the shim. So I’ve ordered some skinnier shims to try.
Also the car started to get hot. The needle crept up 3/4 a couple of times. A cool down lap brought it back down again.
Then on the last session I was getting big vibrations on braking. So I’m worried I’ve warped the discs.
Then the biggest problem was discovered today when it had its post track day oil change. 2 random bits of metal were found in the oil.
I honestly have the worst luck with cars! Although maybe tracking a highly tuned car with over 100k miles on the clock wasn’t the greatest idea.
Anyway, the current plan is to just keep driving it, and if the engine does eventually give up. Then go find a used Golf R engine.  :grin:
  • -Receive: 690
« Reply #31 on: June 20, 2022, 03:52:41 pm »
What colour/size are the metal bits?  You're not the only one with bad luck  :grin:  They do keep soldiering on regardless though  :happy2:
There's a company on Facebook that does turn-key MK7 R engine conversions, otherwise it'll have to be a Golf 6 R/ED35/Scirocco R/S3 engine for easier compatibility.
If you can't get standard issue shims in the gearbox, it doesn't need shimming. You can't take up all the slack unfortunately as VW used plain roller bearings + circlip instead of the more usual taper bearings for some bizarre reason  :stupid:  Another cause of a sticky clutch pedal is crank walk, but hopefully it's just the gearbox, or master/slave cylinders on their way out.  Could even just need a bleed, or the friction disc is binding on the input shaft.
« Last Edit: June 20, 2022, 03:56:42 pm by Pudding »
Offline christii
« Reply #32 on: June 20, 2022, 05:29:06 pm »
Crank walk? I have no idea what that is but it can’t be good! The cars got a brand new clutch, flywheel, master and slave cylinder. The gear changes aren’t the smoothest and on the track day, I struggled to get into 4th gear a couple of times.
Offline christii
« Reply #33 on: June 20, 2022, 06:01:58 pm »
Ok, did a bit of Googling. Crankwalk might be a reality. And those bits of metal might be the left over of a thrust bearing.
If it is “crankwalk”, is it fixable or game over?
Offline Clarkj93
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=m3t33ltko2cf68t06uof2rjbe6&/topic,131272.0.html
« Reply #34 on: June 20, 2022, 08:42:45 pm »
I've been frustrated with the issues my recent track day has brought up but fairplay you definitely win with clumps of metal in the oil pan!
Someone may know better but my understanding when you have crank walk it's either a rebuild or expensive enough repair you may as well do a rebuild while you're there.
Offline christii
« Reply #35 on: June 20, 2022, 09:31:05 pm »
Thanks. I think the plan is no more track days until I get it fixed. I have a GR Yaris coming in August/September time. So hopefully the Golf can stay alive until it gets here. Then I’ll put it in storage until I can afford the rebuild or replacement engine.
Unfortunately there’s no decent specialist over here in Northern Ireland. So I think Decimal Tenths in Newcastle might be the place to take it to. It’s only a 3 drive from Stranraer. And after watching their you tube channel, they seem to know what their doing.
  • -Receive: 690
« Reply #36 on: June 21, 2022, 03:15:21 pm »
Usually you just need a new thrust bearing if it is indeed the problem. It is unfortunately an engine out job (unless they fancy dropping the crank in situ), so it might make more sense to put a better engine back in!  Out with the old, in with the new  :grin:
I think I win the woes competition with 120psi compression readings across all 4. Should be 175-200!  Well I suppose it is at least consistently sh1t across the whole bank  :grin:
Offline christii
« Reply #37 on: June 21, 2022, 03:43:36 pm »
I agree that a new improved engine would be great, but it’s gonna be expensive to buy, plus you don’t know what you’re getting. It might come with a bunch of new issues. I’ve also spent serious money on the engine already, I wouldn’t have to worry about swapping the parts over or replacing them if they don’t fit. (Depending on what engine I went for).
I’ll try the new skinnier shims when they arrive, I might as well since their on the way.
And if they don’t fix the gear change and clutch issue (I’m pretty sure they won’t now) then I’ll come up with a game plan.
  • -Receive: 690
« Reply #38 on: June 22, 2022, 01:56:46 pm »
Yup. A K04 'long block' (no turbo or ancillaries) engine from VW/TPS is about £4K, and I imagine the K03 GTI engine will be around the same.  At least buying new from the manufacturer guarantees a successful install and life span, unlike a lot of rebuilds or used engines.
So if you replace the turbo, clutch, flywheel, injectors etc at the same time, you're in for £6-7K to do it properly.  Hence why so many GTIs end up in the bin when their original engines let go.
That kind of money opens up the doors to newer, more powerful engines, but with the wiring and other compatibility hurdles to overcome, you're in for the same amount, or more!
It's a tricky one!
Offline Clarkj93
« Reply #39 on: June 22, 2022, 03:36:36 pm »
If mine went first thing I'd do is probably call a nationally known specialist like decimal tenths or aks tuning as they may have something on a shelf to go and you know it would be checked over thoroughly not some junk that a breaker might try to flog. Also any race teams that's specialise in tfsi powered cars as they will should have something spare ready to go if one of theirs or their customers tfsi engine dies on or near a race weekend so they don't miss out on the races, TRS, Retro Resus and Jabba sport are a few, again they won't want junk they'll make sure it's good and able to take abuse.
If not I imagine they'll known someone or would source one and send it over on a pallet for a reasonable fee.
  • -Receive: 690
« Reply #40 on: June 23, 2022, 02:32:45 pm »
VAG Technic and REPerformance are worth a shout as well.  The latter built a 1000hp engine for EcoTune's 8 second RS3 drag car  :happy2:  I think that engine has had over 600 dyno pulls and done countless 1/4 miles, and it's still in one piece  :surprised:
The trouble with modern VAG engines is once they come apart, unless everything is spotless and within tolerance, they're pretty much junk.  Hence why I would only get a crate motor from VW if I was to do a replacement, rather than repairing the original one.  The only time I would entertain a rebuild is if it was a 'built' (or fully forged as the kids say) motor from the aforementioned specialists, as all the pistons, rods etc are uprated anyway.
Offline christii
« Reply #41 on: June 24, 2022, 10:56:51 pm »
Thanks guys for the advice. I think a new engine is too much of an investment. A new engine is a good bit more than I paid for the car!
How much do think an engine rebuild from one of the top guys would cost? And worst case scenario, imagine my engine is in bad shape.
  • -Receive: 690
« Reply #42 on: June 24, 2022, 11:40:23 pm »
Holy metal crumbs batman, I've just seen the carnage pics.  They look suspiciously like the thrust bearing remains we were talking about to me, which might explain the gear engagement issues, aka, crank walk.
The thrust bearing on these engines is a terrible design, basically only half a bearing compared to the usual standard.  I pity the later EA113 engines with the clutch down to start the engine nonsense. No oil pressure on the bearing whilst cranking.....what the frick were VW thinking  :stupid:
As for a rebuild/new engine. I doubt the cylinders or top end have suffered, you probably just need a new thrust bearing, which is like 40 quid, but the labour to replace it is 4 figures. Engine out job.
Golf GTIs were never meant to do track work.  Too much oil surge in the corners and not enough preventative measures to safeguard the engine against it.  Later Golfs, MK7 and on, are even worse for it. Clouds of blue smoke on track days due to oil surge having nowhere to go but up through the PCV or blowing out the rear crank seal.
I admire you chaps who track GTIs but honestly, I would stick the GTI to road duties only and buy a second car for track work, something designed for it like a Caterham.
Offline Mekaniko
« Reply #43 on: July 23, 2022, 04:43:34 pm »
That’s experiencie taking.
Offline christii
« Reply #44 on: November 13, 2022, 06:57:38 pm »
Bit of an update on the Golf.
I took it over to Decimal Tenths in Newcastle upon Tyne to have the engine properly diagnosed and hopefully rebuilt. I've been watching Nicks Youtube channel for a while and I was confident it would be worth getting the ferry over for.
Hopped on the 7.30am ferry and was in Newcastle by 1pm. Nick gave me a lift into the city centre, I grabbed some food, had a walkabout then got the Metro to the airport. It was all very easy.
Unfortunately by Thursday the diagnosis was complete and I got the bad news. The first sentence in the message didn't full me with much confidence;
"Every now and then a car comes in and when we look inside, we are shocked that it was even running." :tired_face::joy:
So basically the crank walk is as bad as it gets. There's no thrust washers left at all, the crank has been grinding against the main cap. The flywheel has been grinding against the sump. The crank is moving side to side a good 10mm! The balance shaft has seized solid and sprocket that drives it has completely sheared off. The engine is officially scrap.
I managed to find a used engine for a good price from a breakers yard in Nottingham. It's from a Golf that's been written off from a side impact, and it's only got 85k miles on it. Fingers crossed its a good one. (Can't be any worse than the ship anchor currently in it)
So the plan now is for Decimal Tenths to totally go through this new engine. Carbon clean it, new cam chain, balance shaft delete and new upgraded thrust washers so this doesn't happen again. Its very likely that my performance clutch is what's destroyed the thrust washers, so upgraded ones from Pro-Race Engineering are a must!
Then they'll have to swap all my K04 kit over, and all the new shiny bits I've added to my old engine along the way. It will then need to go onto their Dyno for another remap. Well that's the plan so far. Fingers crossed there's no more nasty surprises.
