Author Topic: Cambelt changed under warranty  (Read 1374 times)
Offline jamesh72
« on: March 31, 2010, 06:53:46 am »
Like a few of you out there,
I was getting the faint chirrup sound at cold idle on my ED30, which many suggest was the cam follower/aux belt.
Anyway, booked my car in, and my dealer swapped out the cambelt itself, so either
a) its still going to make the same noise this morning when I go to work, or
b) mine was different and they've fixed it.
Either way, its saved me a few hundred quid that it was going to cost next year when the car will be 4 years old!
They also replaced a leaky rear light cluster.
So all thats left is the drivers side speakers which work intermittently (must be a loose connection), and we're all sorted!
Offline mohare
Re: Cambelt changed under warranty
« Reply #1 on: March 31, 2010, 06:09:22 pm »
Well at least you won't have to replace the cambelt next year. Did the new cambelt sort the problem out?
Offline jamesh72
« Reply #2 on: March 31, 2010, 06:40:35 pm »
No more squeak! Hurrah!
One question I do have - there are other 'bits' that you generally get done at cambelt change time, like the water pump.
Do I need to get that done next year? Anything else?
« Reply #3 on: March 31, 2010, 07:29:31 pm »
Hmm, it is said that if the water pump isn't changed at the same time as the cambelt then it tends to fail prematurely.   :scared:
Changing the pump alone will incur about the same labour time as the cambelt.
Offline Russ_leeds
« Reply #4 on: March 31, 2010, 10:20:05 pm »
which stealers u go 2? i just had my cambelt n kit changed under warranty and i got them 2 do the waterpump while he had the cambelt and everything off n was meant 2 be bout £45 but never charged me 4 it wen i picked the car up!!
they wont change my lights, they fill up with steam with the lights on or off, but it goes the next day n they say this is ok??!! :stupid:
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
