Author Topic: No driver heated sideview mirror, no mirror blinker and no adjustment.  (Read 1158 times)
Offline Thomas.98
Hello,
I’m new to this forum, and hoping someone has had the same problem as me.
So I have an MK5 from 2006. All the “functions” on the driver side sideview dont seem to be working. No heating, no blinker, and no adjustments can be made. I checked te wires from the door to the interior, pulled back the rubber and i don’t seem to be damaged. I also removed the door pannel and measured the cabels with a multimeter. They seem to be fine. What was also weird that the multimeter gave 0,7 volts on the 2 wires going to the heated mirror. Could this be a faulty module (the one the window motor is attached to?) Any ideas how I can diagnose further?
Thanks in advance.
Thomas
Re: No driver heated sideview mirror, no mirror blinker and no adjustment.
« Reply #1 on: January 11, 2022, 04:25:37 pm »
Any fault codes with a scanner?  I could be wrong, but do some of the mirror functions go through the door controller?  If that is faulty, it might explain it.
Offline Thomas.98
« Reply #2 on: January 15, 2022, 04:17:41 pm »
Thank you pudding for your answer.
So I went out and bought the HEX-V2 scan tool.
I have got an error code on 42-Door Elect. Driver
    Address 42: Door Elect, Driver       Labels: 1K0-959-701-MAX3.clb
Control Module Part Number: 1K0 959 701 N    HW: 1K0 959 701 N
  Component and/or Version: Tuer-SG         005 0961
           Software Coding: 0000052
            Work Shop Code: WSC 00046 412 303104
                      VCID: 392F2FCDA5568143A0F-806C
1 Fault Found:
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
            002 -- Lower Limit Exceeded
Is this a module that maybe frequently fails? If I can't find anything else, I'll go ahead and install a new one and post the results on this post.
Thomas
Offline LC5F
  • -Receive: 80
« Reply #3 on: January 16, 2022, 04:48:28 pm »
That's just saying its not receiving the expected voltage - so hold off sourcing a replacement.
Broken wires in the rubber boot near the hinges are a common issue - have you checked these? - there is a nack to unclipping the boot, there is a latch at the top.
Also some people report unclipping the loom connecter under the boot and giving it a good squirt of contact cleaner can solve door issues.
Offline Thomas.98
« Reply #4 on: January 17, 2022, 05:10:21 pm »
Thanks for the help. When I was tugging the wires to spray them with contact cleaner, the thin red/yellow wire snapped. This was the problem after all. Missed that one with the multimeter I gues. Made a DIY repair, everything working fine now.
