Author Topic: headlight lense removal  (Read 1062 times)
Offline ald1717
  • -Given: 17
  • My Ride: mk5 gti
« on: February 21, 2022, 10:27:01 am »
need to clean the inside of the headlight, can it be done?
only reference ive found says to heat up the seal around the edge with either heat gun or in the oven for 1 minute and then pull the lense clean and re seal,
anyone actually done it
Offline ljc19630
Re: headlight lense removal
« Reply #1 on: February 22, 2022, 06:49:18 am »
Why do you need to get inside the lense?
The can be removed using a heat gun, but its a proper ball ache, plus if not fully and properly resealed you'll get leaks and condensation
Offline ald1717
  • -Given: 17
  • My Ride: mk5 gti
« Reply #2 on: February 22, 2022, 08:25:08 am »
the bulb connector failed and heated up the reflector and lense and now its a bit cloudy, i have done my best with a bit of sponge tapped to a wire coat hanger and gone through the hole for the bulb but cant get it properly clean, its annoying me as the other 1 is like new
Offline LC5F
  • -Receive: 80
« Reply #3 on: February 22, 2022, 08:35:36 pm »
Easier to replace the entire unit.
Offline Octoparrot
  • -Receive: 102
« Reply #4 on: February 23, 2022, 12:38:50 pm »
What he said.
Offline ald1717
  • -Given: 17
  • My Ride: mk5 gti
« Reply #5 on: February 23, 2022, 08:16:23 pm »
i guess if thats the only other option then theres nothing to loose trying it, no rush i suppose
